Who wants a moome 10-bit HDMI input card for the XG ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 71 Old 07-29-2007, 11:32 AM - Thread Starter
Gary Murrell's Avatar
guys
moome is counting hands on who wants a hdmi input card for the fabulous NEC XG projectors?
Moome's new work is said to be night and day vs the older DVI models, plus full 10-but HDMI vs DVI, less banding and gradients, my VP50 will be very happy
I am the first and he needs 30
http://www.curtpalme.com/forum/viewt...?p=67178#67178
lets see them hands
and there better be 29
-Gary
Gary Murrell is offline
post #2 of 71 Old 07-29-2007, 11:44 AM
MikeEby's Avatar
One for me! Edit: Will this have Gamma fix circuits too?
MikeEby is offline
post #3 of 71 Old 07-29-2007, 12:41 PM - Thread Starter
you'll have to ask moome about that, I want mine without gamma though
-Gary
post #4 of 71 Old 07-29-2007, 02:31 PM
Jesse S's Avatar
Maybe, need way more info.
Jesse S is offline
post #5 of 71 Old 07-29-2007, 04:55 PM
meski's Avatar
I'll take one for the Nec ISS switcher
meski is offline
post #6 of 71 Old 07-29-2007, 08:32 PM - Thread Starter
we are talking about a internal card for the XG
-Gary
post #7 of 71 Old 07-29-2007, 08:35 PM
Quoted: 40 Post(s)
-Gary
Gary,
I would want one if the price is in line with DVI or cheaper.
My DVI never worked even with the new eprom.
It is all about quality. That is the picture.
JVC DLA-RS20, NEC XG-1352LC 8" CRT, 106" wide StudioTek 130 screen
CaspianM is offline
post #8 of 71 Old 07-29-2007, 08:42 PM
Mark_A_W's Avatar
I've just gone back to pure analogue for my signal chain.
The ISS card works, but it's black clamping is wrong for my CRT monitor, and when driven by my new Ati HD2600XT it didn't look very good.
Went back to analogue, even through a DVI to VGA adapter and a breakout cable, and it looks better.
Loving my Electric Bike!!
Mark_A_W is offline
post #9 of 71 Old 07-29-2007, 09:18 PM - Thread Starter
Caspian, Kal over at Curts Forum said details and pricing would be identical to the current Marquee and Sony models
so we are talking around 300$ I guess
http://www.curtpalme.com/forum/viewtopic.php?t=5516
I have been waiting for this for so long, can't wait to get it, I count around 5 or 6 so far
-Gary
post #10 of 71 Old 07-30-2007, 12:56 AM
kschmit2's Avatar
That is truly weird.
My PJ has never looked as good as it does now with the HD 2600XT and through the ISS-HD card.
kschmit2 is offline
post #11 of 71 Old 07-30-2007, 01:13 AM
Mark_A_W's Avatar
That's VERY interesting.
Can you please post your timings Kai?
1080i 96hz?
Which card do you have exactly? I have a Sapphire HD2600XT GDDR4.
My interlaced res's didn't work, and progressive ones didn't look good at all.
Are you having any posterisation issues with the 2600XT? VMR9 is totally unusable for me with Mpeg2 video (1080i or 576i).
Overlay works ok, but I've always preferred VMR9.
I'm going to try a borrowed HDMI to HDMI cable, rather than a DVI cable (dell monitor one) and a DVI to HDMI adapter.
Do you still have the shadowing on a CRT monitor? (XG doesn't show this).
Mark_A_W is offline
post #12 of 71 Old 07-30-2007, 06:21 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Hyjack!
mark haflich is offline
post #13 of 71 Old 07-30-2007, 08:00 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
I literally just bought an XG yesterday. Would this card fit into one of the blank input slots at the back of the projector? Looks like I have two blank covers. I would be interested in an internal HDMI card if it's pretty plug and play.
dropzone7 is offline
post #14 of 71 Old 07-30-2007, 10:41 AM
kschmit2's Avatar
Timings as per my post in curt's forum:
http://www.curtpalme.com/forum/viewt...?p=32777#32777
1080i96
Sapphire HD 2600XT DDR4 here too.
To switch to 1080i96 I have to do the following:
switch to that res using a Powerstrip hotkey, then go into display properties, monitor, select 29 Hz, Interlaced.
I'm having no posterization issues, but I use Vista Ultimate 32 bit, and EVR whenever possible.
Will have to look at VMR9 later.
I no longer have any shadowing.
Cable is a DVI-D -> HDMI cable.
1080i 96hz?
kschmit2 is offline
post #15 of 71 Old 07-30-2007, 10:42 AM
kschmit2's Avatar
Yes, that's what the card will be made for.
And it should be pretty much plug and play.
kschmit2 is offline
post #16 of 71 Old 07-30-2007, 01:25 PM - Thread Starter
yep, thats the idea, a fully HDCP HDMI input, slide it in one of the blank slots and off you go
-Gary
post #17 of 71 Old 07-30-2007, 08:19 PM
Mark_A_W's Avatar
Originally Posted by mark haflich View Post
Hyjack!
Not really, the card we have is exactly what you guys are after, just in a different form factor.
The issues we have will affect you too.
The ISS card has a black clamping/shadowing issue on some displays. The analogue tracks across the card are not 75ohm co-planar microstrip, his analogue design is probably not optimised.
And for some reason with my new videocard it just looks nasty on a simple res like 1280x720p. It's overblown and blurry.
As it's working for Kai I will mimic his settings and see what happens.
If I can't sort them I'd be thinking twice about jumping on the HDMI bandwagon if I were you. But if you prefer to be in the dark, fine with me.
I was happy with my ISS card at the start, but as I delve deeper into it and try if with different hardware, I realise it's far from perfect.
Mark_A_W is offline
post #18 of 71 Old 07-31-2007, 12:15 AM
MikeEby's Avatar
Not to Hijack but:
I and the same problem with my Gen 1 Moome internal. I tweaked the gamma in the Nvidia driver and now it is MUCH better, running 1600X900 @ 60 Hz the EDID chip in mine right now will not sync on anything but 60Hz. Hope the update fixes that. I am back to rich blacks and I do think the picture is slightly sharper with the all digital signal path.
Now just install the HD-DVD drive in the HTPC and we should be close.
Mike
MikeEby is offline
post #19 of 71 Old 07-31-2007, 06:46 AM
cbt
cbt's Avatar
Moome offered me this XG hdmi card option months ago and i'm still waiting.
So yes count me in!
cbt
cbt is offline
post #20 of 71 Old 07-31-2007, 07:53 AM - Thread Starter
thats around 8 or 9 hands so far
-Gary
post #21 of 71 Old 07-31-2007, 10:20 AM
larrykelly's Avatar
I am definatly in! I am not sure if I should order gamma though. I posted on the other moome thread a question whether there is an advantage to ordering gamma if all signals will be put through the lumagen. Is the lumagen gamma correction as effective? anyone have an idea how long now? I thought this poll was done months ago and we were just waiting for them to be built. I did contact moome with an intent to order and he responded as follows.
"thanks for your interest, the hdmi card for XG will be ready in July.
currently is external box for most crt projector. here is spec, please look if you need!"
So it looks like it will take a little longer, that's fine but I sure would like to know how long as I am putting things together now and if it is going to be months, I will pick up a Fury until the moome card arrives but only if neccessary then sell it off.
larrykelly is offline
post #22 of 71 Old 07-31-2007, 11:31 AM - Thread Starter
Larry, you do not need anything Gamma wise if you have a Lumagen
-Gary
post #23 of 71 Old 07-31-2007, 06:51 PM
larrykelly's Avatar
then the basic model it is. I am ready to put down the cash so count me in on your poll.
post #24 of 71 Old 08-01-2007, 02:09 PM
kal
kal's Avatar
Quoted: 16 Post(s)
Liked: 76
I've sent another email to Moome to remind him that there are very interested XG owners so selling 30 shouldn't be a problem.
Stay tuned guys. He's got his Sony/Marquee boards to test and get out (he's in the middle of this now) and the EXT-HD external model's getting closer to done, and then the NEC XG version will likely start to see the light of day.
I've started a placeholder thread where all known information will be posted. Subcribe to that thread and you will be notified every time there is news (I post the news as a new post but then also update the first post so that people don't have to search through 200 page threads).
Kal
kal is offline
post #25 of 71 Old 08-01-2007, 03:26 PM - Thread Starter
Thanks Kal, much appreciated
-Gary
post #26 of 71 Old 08-02-2007, 05:26 PM
WGK
WGK's Avatar
Please count me in for 1 unit. (XG1352 internal)
Bill K
WGK is offline
post #27 of 71 Old 08-05-2007, 05:41 AM
Gaber's Avatar
Count me in for one for my XG1351. Is Moome looking for any sort of deposit upfront?
Gabe
Gaber is offline
post #28 of 71 Old 08-05-2007, 07:45 AM
kal
kal's Avatar
Quoted: 16 Post(s)
Liked: 76
No - "Buy Now" buttons will be available when it gets closer to being complete.
Kal
kal is offline
post #29 of 71 Old 08-05-2007, 10:02 AM
moome's Avatar
i have discussed with Kal, i will make XG HDMI as next product!
moome is offline
post #30 of 71 Old 08-05-2007, 03:49 PM - Thread Starter
now where talking
-Gary
Reply CRT Projectors
