HDCP stripper, hdmi in hdmi out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 65 Old 09-19-2007, 12:19 PM - Thread Starter
Chuchuf's Avatar
Is there an HDCP stripper out there that is HDMI (or DVI) in as well as HDMI (or DVI) out?
How about one that is HDMI (or DVI) in as well as twi HDMI (or DVI) out that can be used at the same time?
Both must support 1080P
Terry
AVS Marketplace or Videogon are the places to see F/S ads
Chuchuf is offline
post #2 of 65 Old 09-19-2007, 12:35 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
moome has one his freind is making. look inthe for sale forum DVI/DVI repeater.
http://www.avsforum.com/avs-vb/showthread.php?t=779887
Post #62 lists the input outputs
Athanasios
nashou66 is offline
post #3 of 65 Old 09-19-2007, 01:08 PM
Art Sonneborn's Avatar
Quoted: 238 Post(s)
Liked: 295
Terry
Weren't the Dtronics units just that ?
art
My HT
iRule rules my theater
Art Sonneborn is online now
post #4 of 65 Old 09-19-2007, 02:13 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
I dont think the Dtronics handel full 1080p.
Athanasios
nashou66 is offline
post #5 of 65 Old 09-19-2007, 03:14 PM
alan halvorson's Avatar
The Dtronics DD-D12 Distribution Amplifiers (strips HDCP) are DVI in, two DVI out. There was also the DD-D15 with four DVI out, but I've never run across one of those.
alan halvorson is offline
post #6 of 65 Old 09-19-2007, 05:51 PM
Gino AUS's Avatar
Terry, why not the moome external? 2 HDMI ins, 1 DVI out
( B ) ( G ) ( R ) BlendZilla DownUnder ( R ) ( G ) ( B ) - Tubes of Fury
Gino AUS is offline
post #7 of 65 Old 09-19-2007, 07:01 PM
xcj
xcj's Avatar
http://kvmshop.dk/product.asp?produc...sub=895&page=1
http://www.worldgate.pt/proddet.php?Produto_ID=644
These are not expensive, they do not say that they strip HDCP , but in order to do what they state they can do , they simply have to...
xcj is offline
post #8 of 65 Old 09-19-2007, 08:40 PM
damon's Avatar
I am on the list & awaiting the Moome EXT-HD. Scared the crap out of me when I saw the post indicating it would not work to strip hdcp.
Gino & Kal have now clarified that it can be used to perform this function.
m. conner
Mark Conner
damon is offline
post #9 of 65 Old 09-19-2007, 11:00 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
m. conner
I asked this long time ago as well and so did gino.
Originally Posted by nashou66
Moome is this board the same as the dvi/dvi repeater your making?
Athansios
Moome:
no this is HDMI-VGA box, the other thread is my friend's HDMI-DVI!
Originally Posted by Gino AUS
No rush moome, I'd rather someting that was tested and working.
So DVI is only for digital test, but is the HDCP encryption still carried or has it been stripped? My plan is to use your external box from my HDMI sources, before entering my video processor. I would much rather connect to the VP via DVI than analog, but I can only do this if there is no encryption over DVI.
Moome:
the DVI test port will release HDCP! but it made for test only! it is not legal to have that output!
So it looks like only the dvi port will strip HCDP and the other ports will pass it. But will it pass 1080p to the rgbhv?
Id rather get the dvi/dvi repeater since it also has two dvi outputs that mirror each other which can be used for a future blend or stack .
here is a link tot he data sheet
http://www.avsforum.com/avs-vb/attac...6&d=1182309402
And a link to a pic of the out put side. looks like two hdmi and the dvi . He said that the ports will mirror each other , now i wonder about three?
http://www.avsforum.com/avs-vb/attac...6&d=1187789386
Athanasios
nashou66 is offline
post #10 of 65 Old 09-19-2007, 11:29 PM
Gino AUS's Avatar
This is somewhat incorrect. You only have another choice of vga or rgbhv output and being analog, there is no hdcp. DVI is the only digital output and will strip hdcp from the dual HDMI inputs. Component inputs will not be able to be output via DVI. Gamma corrections are not applied to DVI output. All resolutions and framerates are officially supported over both analog and digital so long as it is below 165Mhz pixel clock.
Gino AUS is offline
post #11 of 65 Old 09-19-2007, 11:55 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Thanks for the clarification Gino, that sounds right. So what do you think of his DVI/DVI repeater box? I eventually want to blend using two Tv-one 2250's and this box would be perfect to strip the hdcp and then send to the Blend units keeping it digital all the way to the VIM-HD. The only thing with this set up is i will ahve my lumagen in front as my source switcher and doing the 11 point gamma correction but then it occured to me that the lumagen will be doing the gamma for both projectors which really isn't the way to go since no matter how close you try to match projectors they never will be exact. so now it might take another lumagen HDQ. This way I would be using 2 HDQ after the the moome DVI repeater box. What would you do , I thought about using a single box blend solution but i like using the lumagen for the aspect control and this wouls need to be in front of the blend units for best results i think, any thoughts?
Athanasios
PS: this is alot of cables!
nashou66 is offline
post #12 of 65 Old 09-20-2007, 04:14 AM
Gino AUS's Avatar
well, looks like you'll need a number of vp's. one for your sources at the start of the chain, and one for each of your projectors to control your grey scale and gamma individually. perhaps speak to andy to see if this sort of control is available on the tvone units
Gino AUS is offline
post #13 of 65 Old 09-20-2007, 05:16 AM
dochlywd's Avatar
Gino,
Did you say that the gamma doesn't work over DVI out? I don't fully understand all of this, but if I have a G90 with RGB in, a Lumagen HDP, Toshiba XA2, Motorolla cable box, and an SDI Panny RP 91, then would or how would I benefit from the new Moome external box with component and 2 HDMI in?
Thanks for the explanation. I pre-ordered but am now thinking of canceling after reading the above posts.
Doc
dochlywd is offline
post #14 of 65 Old 09-20-2007, 06:26 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
I think the External HD box will allow the hdmi to output 1080p to the analog outs where now your lumagen will not. Is this Right Gino, Kal? At least this is how i understand the specs.
Gino I wasnt even thinking of source switching upfront if i had to use two Lumagens on the back end to control 11 pt gamma. Hmm Maybe i'll have to wait for the Lumagen Radiance and use that up front and the moome dvi repeater after my only HDCP source my LG BH100 and all other sources into the lumagen then the dual outs to the TVone scalers . But now that i'm thinking do you really think individual control of 11 pt gamma is really nessasary? the TVones has gamma control inthe blend zone. Andy also tells me that they are working on some other software features.....i cant remeber if there was gamma control for the rest of the image also....maybe this will be one of the features they will add. But this will all be mute point if Lumagen adds blending to the radiance or radiance pro(XS).
Athanasios
nashou66 is offline
post #15 of 65 Old 09-20-2007, 06:35 AM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
I think you might be better off with a HDFury to connect your HD-XA2 to the Lumagen.
And use the Lumagen's gamma controls... Menu 0 9 1 0... Grayscale calibration: Menu->IN->COLR->CTMP
The HDP lets you input RGBHV (e.g., from the HDFury)...
http://www.lumagen.com/testindex.php?module=hdp_details
Input 4 can be Component (HD/SD), RGBS (uses in5 for sync), RGsB, RGBHV (uses 5 & 6 for H & V sync)
But note that the Lumagen HDP can't do a full 1920x1080P@72.
So you either have to use 1080P@60, or you can decrease HRES to about 1800 and use 1800x1920 @71.928
Clarence is offline
post #16 of 65 Old 09-20-2007, 07:38 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Clarence, do you have like a clip art cd with all this schit on it ! man ! your nuts in a good kinda way!
Athanasios
PS let me see you do all that with my possible set up
Two mArquees,two C2-2250, lumagen, dvi/dvi repeater, LG BH100, Dennon 1600 sdi mod, pioneer elite dvl 91, Dish network 222
nashou66 is offline
post #17 of 65 Old 09-20-2007, 07:44 AM - Thread Starter
Chuchuf's Avatar
Alan,
Thanks for the reply. This is one of the units I have been looking at. But are we sure that it will "strip" HDCP where with an HDCP source on the input I can put a non-HDCP device on the output?
Terry
Chuchuf is offline
post #18 of 65 Old 09-20-2007, 07:45 AM - Thread Starter
Chuchuf's Avatar
Because I want 2 out, not one and they must both be active at the same time.
Terry
Chuchuf is offline
post #19 of 65 Old 09-20-2007, 08:18 AM - Thread Starter
Chuchuf's Avatar
How about this product??
http://www.digitalconnection.com/pro...video/1392.asp
It is 1080P, one in 2 out HDMI, HDCP compliant but does that mean it will allow a non HDCP device on the output and open the output.
My thoughts are HDMI HDCP source -> HDMI in VP50 HDMI out-> HDMI in 1392 HDMI out-> ->two DVI in's DVX8022 two DVI outs-> HDMI in's projectors with Moome cards.
That way digital domain all the way to the PJ, no D/A till the Moome card, and dual in's on the DVX8022 for added setup flexibility.
The DVX8022 is not HDCP compliant.
Think this will work??
Terry
Chuchuf is offline
post #20 of 65 Old 09-20-2007, 08:36 AM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
Athanasios
Clarence is offline
post #21 of 65 Old 09-20-2007, 09:01 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
LMAO ! Clarence you rock! but if you did a little research you could have fond the image if moomes dvi/dvi repeater in his forsale post.
Athanasios
nashou66 is offline
post #22 of 65 Old 09-20-2007, 09:14 AM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
Here's what I envisioned...
I don't see what you need 2 HDMI AA1392 for.
And does the DVX8022 have 2 DVI inputs? I only see 1 DVI input and lots of BNC inputs...
Is the 2nd DVI input an option that isn't pictured?
Clarence is offline
post #23 of 65 Old 09-20-2007, 09:25 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
I love these little illustrations Clarence does with the equipment. It really helps those of us like myself that have difficulty envisioning how everything works and where it all falls in the AV chain. A similar diagram is what convinced me that CRT would work with my simple setup and ultimately I bought a PG from Clarence. That guy can do anything.
dropzone7 is offline
post #24 of 65 Old 09-20-2007, 09:33 AM
damon's Avatar
Clarence,
You have the chain right but my two Ultras have Pininfarina cases. Get with it buddy.
Mark Conner
damon is offline
post #25 of 65 Old 09-20-2007, 09:51 AM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
you need to hit refresh (shift+F5) on your browser
Clarence is offline
post #26 of 65 Old 09-20-2007, 09:56 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
Yeah, but it's a blend...not a stack. JK
post #27 of 65 Old 09-20-2007, 10:09 AM
Clarence's Avatar
Quoted: 282 Post(s)
Liked: 9686
hit refresh again
Clarence is offline
post #28 of 65 Old 09-20-2007, 10:13 AM
dropzone7's Avatar
Quoted: 119 Post(s)
Liked: 95
post #29 of 65 Old 09-20-2007, 11:10 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Chucuff is not relizing you only need one input to the Di-Ventix. then it splits the image int to equal images inside and feathers the edges on either left or right.
Athanasios
nashou66 is offline
post #30 of 65 Old 09-20-2007, 12:37 PM
nidi's Avatar
Alan,
Terry
Terry,
I tried 2 Dtrovision boxes (one being one from the first batch) with an HD-DVD player to the Crystalio 2. tried all different ways (power on , off , ..)
couldn't get that thing to output a picture (actually , both of them)
wouldn't a sinple 'smart' plug HDMI HDCP in - HDMI no HDCP out be the
great gadget to buy ?
Michael
nidi is offline
Reply CRT Projectors
