Marquee LVPS +-85V refinement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-14-2007, 12:36 PM - Thread Starter
fvale's Avatar
I'd like to replace the 3 x 100V 100uF caps in the LVPS +-85V outputs with higher quality parts (idea is to use FK series BlackGates). Do someone have already worked and tested on this?
Would it be better to higher this capacity a bit?
Can someone explain why on the +85V there are two of these caps paralleled, while on the -85V only 100uF are used?
fvale is offline
post #2 of 8 Old 10-14-2007, 02:02 PM
mp20748's Avatar
Quoted: 106 Post(s)
Liked: 26
This has already been discussed several times.
Those three caps should be replaced, but 105c (temp) should be the replacement caps. Do not use 85c (that's what the originals are). The 85c caps are not good for switching power supply rails, therefore they flake out. The lower temp caps were used in the supplies, and later it was found that they were not good for SMPS rails.
It's OK to go higher capacitance, but there's no reason to go with boutique caps. When going higher it would be a good idea to not go too high, because the SMPS will delay in firing up (click several times), It may see the added capacitance as a load and try try to shut down.
consider these:
- 100mf @ 160 vdc / 105c
- 100mf @ 250 vdc / 105c
- 150mf @ 160 vdc / 105c
The 100mf @ 259 vdc / 105c seems to be the best way to go, because it keeps the same load on the supply. And the higher voltage rating seems to do the same thing that would be expected from going higher capacitance.
The +85 volt rail also supplies the deflection sweep circuit drive (power mosfets), so that may explain why there's two of them on that rail. While both -85 and +85 are the supply for the neck boards
While you're at it. Also replace C50 (220mf @ 160vdc) on the HDM. And if you can, replace it with a 220mf @ 260 vdc 105c
If C50 leaks, it will not only cause width and unstable width problems, it can cause the heatsink to run hotter, as well as dump sweep noise on the +85 rail into the neck boards.
Stay away from boutique caps. Simply making sure the caps you use are 105c is all that needs to happen in these circuits.
It's all about the performance... Got Marquee!
High Performance Marquee Video chain modifications.
mp20748 is offline
post #3 of 8 Old 10-14-2007, 02:26 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Mike would changing C50 possible help with being able to increase the width of the raster? I added the jumper to p7 on the hdm but it hasnt had any effect in increasing the widht to match my other projectors width. I have to put one projector further back with respect to my ceiling mounted PJ to get it to fill the screen.
Athanasios
nashou66 is offline
post #4 of 8 Old 10-14-2007, 03:27 PM
mp20748's Avatar
Quoted: 106 Post(s)
Liked: 26
Athanasios
There have been times when C50 has improved on the width, but it's not something I think will happen everytime the cap is changed.
It would also be good to check the +85 volt rail. If it's below +85, it can effect the horizontal deflection range.
There's a +85 pot on the LVPS for this.
mp20748 is offline
post #5 of 8 Old 10-14-2007, 03:51 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Where do i check this ?
Athanasios
nashou66 is offline
post #6 of 8 Old 10-14-2007, 09:51 PM
mp20748's Avatar
Quoted: 106 Post(s)
Liked: 26
Athanasios
If you know where the filament connector (P14) is located on the main PC board right near the blue CRT. The +85 volt feed to the board is the next pin over from P14. It is marked "+85"
mp20748 is offline
post #7 of 8 Old 10-14-2007, 10:25 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Yes i know it ok thanks mike!
Athanasios
nashou66 is offline
post #8 of 8 Old 10-15-2007, 12:41 PM
WTS
WTS's Avatar
Quoted: 37 Post(s)
Hi fvale,
Even though the Blackgates are 85c caps don't worry about that, they'll probably last longer than most 105c rated caps, the blackgate cap are an excellent cap, use them. Like MIke said you can go higher in cap value but don't go over board.
The reason there is 2 caps on the +85 compared to 1 on the -85 is probably due to the fact that there is more current draw on the +85 so to keep the ripple down they doulbed up on the cap value.
Walter
WTS is offline
Reply CRT Projectors
