Chuck Williams Fan Mod, WOW!! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2002, 03:16 PM
Continuum37's Avatar
Please email me a mod plan for a Sony 1270 if at all possible.
Ken
Ken_Pitzner@mail.utexas.edu
Continuum37 is offline
Old 06-11-2002, 02:02 PM
Keith Murray's Avatar
Quoted: 23 Post(s)
Could someone send me the schematic to mod an NEC 9PG?
Keith
keithm no@spam casco.net
Keith Murray is online now
Old 06-26-2002, 01:20 PM
rail's Avatar
Has or can this fan mod be done to a Barco 1208s? I have a short ceiling(7') and an"8" riser which puts my head right under the projector, making it difficult to hear movie dialog during quiet scenes. I don't think I have enough room for a hush box. Also, how do I go about getting the supplies and directions for the modification? Thanks.
Gary
rail is offline
Old 06-27-2002, 04:35 AM
stefuel's Avatar
Quoted: 37 Post(s)
Liked: 24
You wanna know the funny part? When I installed my NEC, the first thing I noticed was how quiet it was compared to the ECP it replaced. When I installed the ECP, I was floored by how quiet it was compared to the bulb PJ it replaced. A stock 9PG is supposed to emit 45 DB and the ECP 55 DB. I sold the bulb PJ so I don't have the manual for it but it was probably about 65 DB. Not exactly a cost effective way to do it, but I'm happy...
Chip S.
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
Old 06-27-2002, 05:38 AM - Thread Starter
johnboy's Avatar
From What I understand it can be. You should contact Chuck, He'll be happy to send a board or the specs on it
Good Luck
JohnBoy
"Politicians and diapers are a lot alike, they need to be changed often for the same reason".....Mark Twain
johnboy is offline
Old 06-27-2002, 01:57 PM
JSW
JSW's Avatar
Anyone with NEC PG9200 Fan Mod plan? Please send me a copy to jasonsjwou@yahoo.com
plz plz plz
tks tks tks
Jason
JSW is offline
Old 06-27-2002, 09:11 PM
rail's Avatar
Johnboy,
Thanks, I just sent an e-mail to Chuck.
Gary
rail is offline
Old 06-28-2002, 08:28 AM
rail's Avatar
Chuck just sent me the schematic for the NEC PG mod. Thank-you Chuck.
Has anyone actually done this to a Barco? What results did you have and do you have any pointers?
Gary
rail is offline
Old 08-22-2002, 06:14 AM
kaanage's Avatar
Could someone please send me the 1272 mod. My email is kaanage@hotmail.com
kaanage is offline
Old 08-22-2002, 01:35 PM
jjs3's Avatar
Can someone send me the 1272 directions as well?
jackswearhart@yahoo.com
Thanks!!!
Jack
jjs3 is offline
Old 08-27-2002, 06:53 AM
kaanage's Avatar
Anyone? Please?
kaanage is offline
Old 08-27-2002, 05:08 PM
Jerry Arseneau's Avatar
Seeing there is more that one request and guessing that Chuck won't mind, here is a link to a .pdf of original fan mod schematic
You will need to unzip the file and view it with Adobe Acrobat.
Jerry
Jerry Arseneau is offline
Old 12-01-2002, 03:03 AM
Bruno Lovisi's Avatar
UP!
Bruno Lovisi is offline
Old 12-01-2002, 10:24 AM
Energeezer's Avatar
Could someone e-mail me the mod for a 135LC to
energeezer1@hotmail.com
Steve
Energeezer is offline
Old 01-20-2003, 10:10 AM
Blorton's Avatar
I'm interested in the updated schematic as well. If anyone has it, I'd sure appreciate a copy at danbeggs@ceg.dyndns.org.
Are the PCB's available anywhere? I'd much rather go that route if it's an option.
Dan
Blorton is offline
Old 01-20-2003, 01:50 PM
ChrisMcCarthy's Avatar
Is there a reliable fan mod for the AmPro 4600?
Chris
Knowledge is based on facts which are true until proven false. Truth is based on opinion and can't be proven, or disproven at all...
ChrisMcCarthy is offline
Old 01-22-2003, 02:23 PM
Blorton's Avatar
Well? Doesn't anyone have any info on the updated schematic or the pcb?
Should I just break out the BFH to quieten my 1272 down? :D
Any pointers or info would really be appreciated.
Dan
Blorton is offline
Old 01-22-2003, 03:30 PM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
Did you email Chuck?
BizarroTerl is offline
Old 01-22-2003, 08:00 PM
Rickd's Avatar
I have a barco 808 and I know the fans are speed controlled would this effect this circuit in any way presumably both the internal projectors speed control and this one may conflict?
I have the service manuaul so I will check the internal speed circuit perhaps I coul modify that directly.
Cheers Rick
No matter where you go there you are!
Rickd is offline
Old 01-22-2003, 09:52 PM
Blorton's Avatar
Yes I did, several days ago. :) I understand he can be pretty busy at times, I was just thinking surely someone else had purchased the pcb if they had ever been produced.
dan
Blorton is offline
Old 01-23-2003, 05:14 AM
PeteC's Avatar
Here is the updated schematic I got from Chuck about a month and a half ago. It is for a Sony 12XX so I don't know if it is the same for other projetors or not but should work for the Sony's. It's a PDF file.
Pete
If the attachment doesn't work send me an e-mail at
czarnp@parknicollet.com
PeteC is offline
Old 01-23-2003, 05:19 AM
PeteC's Avatar
O.k. it looks like the attachment didn't work. So I am going to send it out to you all through the e-mails you have provided.
Pete
PeteC is offline
Old 01-23-2003, 05:44 AM
Jesper Backman's Avatar
PeteC, please, send to me to:
jesper_backman@se.ibm.com
Jesper
Jesper Backman is offline
Old 01-23-2003, 07:37 AM
fantazia2's Avatar
Chuck,
what voltage are the fans supposed to run at when using you circuit. I tried building the circuit (from http://www.snaggs.com/projector/disp...&pagetitle=NEC) in a program called crocodile technology.
The timer circuit worked alright and switched the relay for about a second, but when I measured the voltage across where the fan/s would be the voltage came out as 1.39v (15v with the initial relay switch), which to me seems quite low, but it could just be the components available in the software.
Also, is there a component list anyway giving the specs on all the items required, i.e. cap types, etc.
Chris.
fantazia2 is offline
Old 01-23-2003, 03:47 PM
Randy S's Avatar
1.39v is not going to cut it. Output voltage is a metered by the zener diode value. Seems like the original design called for a 6.1v, but I was concerned that would slow the fans too much, so I went with a 9.1v.
This is what I had for a parts list. Use at your own risk.
(1) 100 resistor
(1) 470 resistor
(1) 1K resistor
(1) 12K resistor
(1) 56K resistor
(1) 1 N4001 diode
(1) 9.1 volt zener diode
(1) .1 uf ceramic capacitor
(1) 4.7uf electrolytic capacitor
(1) 100 uf electrolytic capacitor
(1) 555 timer lC
(1) 12 volt relay
(1) 7805 voltage regulator
(1) 2N2222 NPN transistor
(1) 2N2955 transistor with heat sink
Randy
Randy S is offline
Old 01-24-2003, 01:47 AM
fantazia2's Avatar
Oops I put the zener diode in the wrong way round. Switched it and now gives out about 9.37v, which sounds a lot more healthy.
Did anyone test their circuit before installing it in their projector, i.e. with a spare fan or removing the fan from the proj and testing externally.
Chris.
Old 01-24-2003, 06:01 AM
Chris,
Last year when I installed the mod in a 1272, I connected 1 fan to check it out. You almost need to test this in the pj because part of what you are checking is whether the fan sense circuit is happy with the lower voltage. One thing I ran into was that some sense circuits needed more voltage to not execute a shutdown.
I am about to build the mod for an NEC XG. Which projector are you working on?
Jerry
Old 01-24-2003, 06:40 AM
fantazia2's Avatar
Hi Jerry,
its a NEC 6PG Xtra. I've had it for about 6 months now and my seating position is below the projector, so I am getting annoyed with the noise now, but its still a lot quieter than my old LCD proj.
Chris
Old 02-02-2003, 04:43 PM
David_Larkins's Avatar
Chuck,
could you (or someone else who can) send me the instructions for the fan mod of the NEC XG110LC?
my address is davidlarkins@chartertn.net
Thanks a lot... I'm ready for some quiet!
David
David
David_Larkins is offline
Old 02-03-2003, 07:09 AM
Doug Baisey's Avatar
Location: Diamond Bar Calif USA 91765 / Seattle area WA 98512
David,
YGM. Chuck is on a vacation, the lucky guy. Doug
Doug Baisey is offline
