TVONE Blending Info, General Q&A or just how to? - Page 30 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #871 of 883 Old 09-21-2013, 10:11 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Decided to bring this old thread back up with some screen shots, now on a 13 foot wide scope screen.
Angels and Demons
Nashou!!!!!!!!
nashou66 is offline
post #872 of 883 Old 09-22-2013, 12:13 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Looking Good Nashou,
How much increase in fl are you getting now the new 9" guns are installed ?
BTW did TVone ever fix the 4.2.2 pass through ?
Cheers..
cinema mad is offline
post #873 of 883 Old 09-22-2013, 02:10 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
No Increase since I increased the screen size from about 11.5 feet to 13 feet or about 4 meters wide now!!! It actually went down a couple fl.
No they never added it its all 444, I use RGB from Oppo to Moome.
Nashou
nashou66 is offline
post #874 of 883 Old 09-23-2013, 09:50 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
A little clip i did with my iPhone to show those who do not know exactly how Blending works.
nashou
nashou66 is offline
post #875 of 883 Old 09-25-2013, 11:44 PM
Oliver Klohs's Avatar
Quoted: 40 Post(s)
Very good demonstration, the blend zone is really small in your setup!
Oliver Klohs is offline
post #876 of 883 Old 09-26-2013, 06:35 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
It is made for about 208 pixels but I find going to 225 hides the zone better. On the 13 foot screen it is about 16-18 inches wide. So yes it is small, my zoom I think is set at 177 after using the 1:1 pixel mapping in the source menu. I'll have to double check when I get home. The zoom is what determines how large the blend zone will be, but when using 1:1 you have to make adjustments and some menu's get hidden so adjustments will not ruin the mapping.
I find the image is more precise allowing the 1:1 and then just going with what it throws out at you wink.gif
There may be other ways to do it but my physical location is set in stone for now I am not moving those damn things for a long long time !
Nashou
nashou66 is offline
post #877 of 883 Old 09-26-2013, 03:39 PM
Quoted: 40 Post(s)
When I experimented with blending I also preferred the smaller blend zones as it gave me better results in both sharpness and phosphor usage for scope screens.
post #878 of 883 Old 11-10-2013, 06:13 PM
pk442's Avatar
So with two G90s in an edge blending setup, what would be the optimal resolution? Primary use would be with blueray, but also some satellite HDTV.
I understand that 2.35 images are only using 1920x800 (or817-whatever the 2.35 image works out to). Where as 16x9 images use the full 1920x1080. Can I still get full 1080 on a 16x9 blueray, or will they all be at 800 ? Do I still need a separate scaler and the Moombe Mux unit? Sorry to ask such stupid questions, but the info is so fractured over 5 years or so, I was just wondering what the current theories were. I currently have one G-90, but there seem to some available for darn little, and I'd love to up my screen from its current 123" size. So I'm just trying to figure out the difficulty/complexity of getting something like this setup, and of course what all it will really cost $$. Thanks for any advice yo may have - PK
pk442 is offline
post #879 of 883 Old 05-02-2014, 12:22 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
The 13 foot blend !!!!!!!
This film is definitely film, lots of grain !!!
Lets See A Digital Do This !!!!!!
Back In Black !!!!
Nashou!!!
nashou66 is offline
post #880 of 883 Old 02-11-2015, 09:45 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
nashou66 is offline
post #881 of 883 Old 05-17-2016, 10:32 PM
fearn48's Avatar
Liked: 0
Originally Posted by nashou66 View Post
Quote:Originally Posted by olakjen
The C2-2450A is the best unit for someone who just wants to blend with DVI/HDMI how ever i found them to have HDCP issues so you would also need
a MOOME MUX-HD as well, i use the MUX as the splitter . So you would go:
BD>MUX-HD>Two C2-2450A's>Two G70's with Moome HDMI Card's
I am still looking for the Price sheet.
I would also suggest another radiance so you can do Greyscale and CMS for each G70. I have two radiance's before the TV-One units.
Athanasios
Hi Nash,
I'm thinking about blending two barco projectors to get around a throw issue I have with using a single projector (can't get the projector back far enough for a picture bigger than 140cm). My options are either a first surface mirror to add throw or blend. I have a couple of questions about blending I was wondering if you could help me with.
1. My picture size with a blend would be about 2 meters wide. Is this too small for a blend with two 9" projectors (Cine Max and Reality 909/919).
2. Why did you put the lumagen units before the TV One units? I'd have thought after would have been better for upping the refresh rate.
3. Do the 2450A units Handel 3D now? You mentioned there was an option in the menus.
4. It's the MUX-HD still needed, have TV One fixed the HDCP issue.
5. Do the new TV One units with hdmi in/out do blending. They don't seem to have it in the description.
Peter
fearn48 is offline
post #882 of 883 Old 05-19-2016, 09:59 AM
dzseki's Avatar
Quoted: 12 Post(s)
Liked: 1
2m wide screen is way too small for blending! Not to mention all the cost and effort involved for such a small screen, a decent 8" machine light that up easily!
So if you are sticking to the CRT the 1st reflection mirror is your only solution with that room.
nashou66 likes this.
dzseki is offline
post #883 of 883 Old 05-20-2016, 01:05 AM
fearn48's Avatar
Liked: 0
Many thanks. I really appreciate the advice. I think your right. I'll be going down the mirror route.
Peter
fearn48 is offline
Reply CRT Projectors
