Amp for this sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-30-2010, 07:45 PM - Thread Starter
MANTI5's Avatar
I'm looking for some suggestions on a good budget(under $200) amp for this sub: http://www.woofersetc.com/p3415/RWE3...-Subwoofer.htm
If there are better choices for this sub http://www.woofersetc.com/p3170/RWE3...-Subwoofer.htm I will go with it instead.
MANTI5 is offline
post #2 of 2 Old 11-30-2010, 10:41 PM
cubdenno's Avatar
Quoted: 65 Post(s)
Liked: 90
http://www.sonicelectronix.com/item_...NX1.1000D.html
Give this one a shot. Either sub will work. the amp does 750@2ohms and 1000@1 ohm.
I would get the dual 4 ohm because the amp will run cooler and the 250 watt difference is like 1db louder @ the 1 ohm load. Amp will be cooler, easier load on your cars electrical system. Most likely sub with the DVC4 will have lower inductance as well. less distortion.
Good luck.
Obviously there are others but this is a good amp. Easy recommendation.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Reply Car Audio, Video, and Nav
