Aura Shakers with JL 250/1 - AVS Forum | Home Theater Discussions And Reviews
Old 12-15-2010, 11:45 PM - Thread Starter
nasium's Avatar
Going to install some Aura Bass Shaker Pros in my car this weekend and need some advice.
Aura Bass Shakers 50 watts rms handling 4ohms.
JL 250/1 mono amp 250 rms.
Trying to figure out how these two could work together. I'm concerned my amp may be too much for the shakers? Could I get around this issue wiring in series? Could I just hook them up as 4 ohms and turn the gain down?
Thanks in advance
nasium is offline
Old 12-16-2010, 03:44 AM
littleant's Avatar
Of course wire them series. And probably you need to adjust the gain also.
littleant is offline
Old 12-16-2010, 10:51 AM
cubdenno's Avatar
Quoted: 67 Post(s)
Liked: 91
Agree. Wire them in series for an 8 ohm load. Then you are looking at 125 watts to the pair which will be fine.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Old 12-16-2010, 12:16 PM - Thread Starter
nasium's Avatar
Many thanks!
nasium is offline
