Blown sub. Need recommendations! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-23-2010, 11:21 AM - Thread Starter
b_j__h's Avatar
I have a single JBL GTO1214D 12" sub in a box in my trunk. It's powered by a JBL GTO3501 amp. Recently the sub seemed to be shorting out and would work and then stop. If I push on the sub, it will start working again and the audio place said it was going out (I think he said the voice coils were hanging up.). Before I go out and spend $140 on another identical sub, I was wondering if there would be any better sub options around the same price.
b_j__h is offline
post #2 of 5 Old 12-23-2010, 01:17 PM - Thread Starter
b_j__h's Avatar
I'm not leaning towards the Infinity Reference 1262w sub.
b_j__h is offline
post #3 of 5 Old 12-24-2010, 10:38 AM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Can you give me the box dimensions or explain your box?
Sealed ported?
Cubic feet (volume)?
Listening tastes?
There are a ton of subs that will fit your needs. I am surprised that the JBL died. They are a great under rated sub. Infinity is in the same company as the JBL (same parent: Harman).
With all the sales going on, it should be easy to find one. Shame Sonicelectronix ran out of the Phoenix gold RSd 12 for 45 bucks. that was a great buy.
On 350 watts I am surprised it died.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #4 of 5 Old 12-25-2010, 12:33 PM
s_carter's Avatar
Check out fi's lineup of X and SSD's they are excellent for lower power alternatives. Though I run over twice what my SSD18's are rated for no problem. (3600 RMS to two rated for 1600 RMS) Even with very little power, they sound great and get loud too, I remember being able to pull hairtricks with only a couple hundred watts to the pair! FI CAR AUDIO
There is also some very good subs from many other companies out there, but I end up buying fi for 99% of my projects and for my customers installs as well.
Sam
Custom Sounds NW
Sam Carter
Custom Sounds NW
Custom enclosures, service and installation of mobile electronics and home theater equipment.
Featured in CAE
My Home Page
DIY Dual 18" Sub Project (MK II)
s_carter is offline
post #5 of 5 Old 12-26-2010, 11:32 AM
eggyhustles's Avatar
Quoted: 14 Post(s)
sundown sa series
eggyhustles is offline
Reply Car Audio, Video, and Nav
