What do I need to use a sub in my car? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-27-2011, 04:56 PM - Thread Starter
skatingrocker17's Avatar
Quoted: 23 Post(s)
I'm getting a Kenwood $1000 watt amp and 2 Elemental Design 15" subs for my car but they aren't coming with any cords. What do I need and where do I get them? Can someone point me in the right direction?
skatingrocker17 is offline
post #2 of 6 Old 01-28-2011, 09:26 AM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Order a wiring kit. it will usually include rca's and speaker wire as well as the power wire. Give knukonceptz.com a look. otherwise even walmart sells a kit. DO NOT undersize the power wire.
Also do you have a factory or aftermarket head unit?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 6 Old 01-28-2011, 09:52 PM - Thread Starter
Quoted: 23 Post(s)
I'm looking at the amp installation kits. I've got a Kenwood DNX6960 and a Kenwood 1000 watt amp.
post #4 of 6 Old 01-29-2011, 12:16 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Uh... people who install 1000 watt amps and 15" sub usually don't ask this kind of question.
This is serious power drain and may need to beef up your wirings, battery, maybe alternator. Else ur looking at electrical probs, interference with ignition, alarm etc.
MrBobb is offline
post #5 of 6 Old 01-29-2011, 08:59 AM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Mr.Bob,
Figure this is a teenager. I have one of these at home or rather did. These same questions always come up. Seriously though, a 1000 watt amp is not a huge drain. I run ~2500 watts in my car total. stock 80 amp alternator, sears Diehard Platinum battery. I have dimming but no other issues. Music does not pull amperage continuously. I have amp clamped my system and on tones I have pulled 138 amps. On music at full volume it never got above 110 amps draw.
My son also had a 1000 watt class D sundown audio amp. on a Mazda 3 hatchback. Stock electrical. Can show the install log. No issues.
So I figure, unless the OP has an old electrical system or components are weak, he should be fine.
XBL-Steelhouse1
cubdenno is offline
post #6 of 6 Old 01-30-2011, 11:21 AM - Thread Starter
Quoted: 23 Post(s)
Mr.Bob,
I ended up getting a 1200 watt Pioneer amp and a 12" MTX and Autobahn. The wires the guy gave me looked crappy and didn't have a fuse so I bought these. He said all it did was make his lights dim and I didn't want any of that.
Reply Car Audio, Video, and Nav
