220A Iraggi load tested 74A :( - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2011, 04:58 PM - Thread Starter
kryptonitewhite's Avatar
I went to Advanced Auto, their load test doesnt do ampers, 1st with car off all electric off:
advanced auto print out
battery test 12.82V
measured 1256 CCA
rated 758 CCA
Temp 21deg F
While stating:
starter voltage 11.74V
0.0A time
625mS
dipped to 10V
running:
Charging system test
no load 14.62V ---A
loaded 15.58V ---A
ripple 37mV
http://www.youtube.com/watch?v=JkAfgEPB9Ds
Went to O'Reilley's
Load test 74A
http://www.youtube.com/watch?v=n9zlvDKBoLk
kryptonitewhite is offline
post #2 of 3 Old 01-30-2011, 05:44 AM - Thread Starter
I had a choice of more power at idle, inbetween, or more peak. The smallest alt is rated 160A-200A at idle 220A peak, the biggest alt is rated 160A-180A at idle 300A peak. I chose 200A idle 220A peak.
I was idling. I should have gotten a minimum of 160A and up to 200A at idle.
Ive had Dominic Irragi on my Facebook since I started my research, he deleted it and started a new one. I added him, bet he doesnt accept! I sent yet another email last nite, we will see
bad alt? good alt?‏
1/29/11
dominick@tds.net
Sent: Sat 1/29/11 9:21 PM
To: dominick@tds.net
Hotmail Active Viewadvanced auto CCA voltage.AVI
Go to YouTube
Play video
advanced auto print out battery test 12.82V measured 1256 CCA rated 758 CCA Temp 21deg F starter voltage 11.74V 0.0A time 625mS dipped to 10V Charging system test no load 14.62V loaded 15.58V…
00:02:50
Added on 1/29/11
Loading video preview from YouTubeThere was a problem connecting to YouTube. This video may not exist or it may only play on YouTube. Try going to their website: YouTube - oreilley 74A load.AVI
I just went to have my 160@idle 220 peak tested, it was load tested as 74A. It is rated 160-200A @ idle, 220A peak. Test no good? I want to make sure the Iraggi works as it should before adding a 2nd alt.
battery test 12.82V
measured 1256 CCA
rated 758 CCA
Temp 21deg F
While stating:
0.0A time
625mS
dipped to 10V
running:
no load 14.62V ---A
loaded 15.58V ---A
ripple 37mV
YouTube - advanced auto CCA voltage.AVI
Went to O'Reilley's
Load test 74A
post #3 of 3 Old 01-30-2011, 08:07 AM - Thread Starter
Reply Car Audio, Video, and Nav
