Product Description: The Clarion NZ409 Navigation Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-01-2011, 09:15 AM - Thread Starter
Lesscovince's Avatar
Motorized/Retractable 7" Touch Panel TFT Display: The Clarion NZ409 has a motorized, retractable 7" TFT wide screen display with touch panel controls. The display provides a high-resolution video monitor for watching your DVD videos. The screen has a resolution of 1440 x 234 and 336,960 total pixels. The display features brightness and aspect ratio (4:3 or 16:9) adjustments. The unit's touch panel features interactive controls and video graphics, making menu navigation easy. An on-screen numeric keypad allows you to directly access titles and chapters of a DVD disc. The touch-screen surface is treated to resist dust and grime.
Display Angle and Position Adjustment: You can adjust the display's angle for better visibility. The display angle can be adjusted from 70 to 110.
2nd Display: The unit also offers an additional one line dot-matrix LCD display for when only listening to the radio or a CD and you don't need the video-screen open.
Front-Panel Controls: In addition to the unit's touch-panel display, the unit features hard-key controls, including two rotary dials, along the bottom front-panel of the unit.
24-bit D/A Converter: The unit's 24-bit D/A converter re-quantizes the 16-bit audio signals from CDs and DVDs as 24-bit data while maintaining the low distortion and high linearity of a 1-bit D/A converter. This allows an expanded dynamic range and clearer reproduction of subtle nuances, for a richer sound when viewing DVDs or listening to CDs.
Electronic Skip Protection: The Clarion NZ409 provides electronic skip protection for your CD-Audio discs (10-seconds), as well as your discs containing MP3 (45-seconds) and WMA (90-seconds) audio files.
Disc Compatibility: The NZ409 can play back the following types of discs.
Lesscovince is offline
Reply Car Audio, Video, and Nav
