Any amp suggestions for a DVC 6ohm? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-02-2011, 11:20 AM - Thread Starter
omegasquid's Avatar
Hey, I just had my friend buy a JBL GTi 15"
DVC 6ohm (x2)
800 watt RMS
5000 watt max
I'm looking to put around 700-800 quality watts into it.
But.. we are having problems looking for an amp. I know if I wire the sub in series it will be a 12ohm load, and in parallel it would be a 3ohm load. Am I correct with these calculations?
Would it be a problem to / How would i go about: push(ing) a 4 ohm amp at 3ohms? What would be any pros or cons to this situation?
omegasquid is offline
post #2 of 4 Old 02-02-2011, 02:54 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
http://cgi.ebay.com/JBL-1500-Watt-Mo...item230de45c9a
http://cgi.ebay.com/JBL-2200-Watt-Pa...item5adecedc86
The above2 amps are going to do what you want.The second one is a true monster read up on the BPX line.
Otherwise, find a class D amp that putts out the wattage you want at a 4 ohm load. Wire the coils in parallel for the 3 ohm load and call it a day. Make sure you use a mono (single channel) amp.
your understanding of the different wiring schemes is spot on.
Great sub by the way!!
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 4 Old 02-02-2011, 06:56 PM - Thread Starter
omegasquid's Avatar
thanks! would a kicker zx1500.1 be suitable? can get a deal right now on it
post #4 of 4 Old 02-02-2011, 09:26 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
that amp should work fine.
XBL-Steelhouse1
cubdenno is offline
Reply Car Audio, Video, and Nav
