Looking for new subs but need help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-02-2011, 10:57 PM - Thread Starter
GaigeK's Avatar
I have the new Pioneer AVH-P3300BT head unit, and a SoundOrdinance Bass Bunker box with 1.03 cubic ft per individual chamber. I want 2 - 12's less than $100 per sub.
Here is the specs on the Amp that I have:
Audiopipe GM-1502
Capable of Being Bridged into a 4 Ohm Mono Output Without Switches
150 Watts RMS X 2 Channel @ 4 Ohm
225 Watts RMS X 2 Channel @ 2 Ohm
Frequency Response: 20Hz-30,000Hz
Signal to Noise Ratio: >100dV
Channel Separation: >65dB, 1 Khz
Mosfet Technology
Adjustable Input Level Control
2 Ohm Stable
Remote Turn On/Off
RCA Line Input/Output
Double Sided Glass Epoxy PCB
Frequency Adjustable High/Low Pass Filter
Electronic Protection Circuitry
Unique, Super Efficient Heatsink Design
Please let me know what you recommend.
GaigeK is offline
post #2 of 8 Old 03-03-2011, 03:51 PM
JMII's Avatar
Amp wants a 4 ohm bridged load: so that is either two 8ohm SVC subs wired in parallel - OR two 4 ohm DVC subs (voice coils in series, subs in parallel). Couldn't find a ratting on the amps bridge output, but I'm guessing around 300-450 watts. So figure 1/2 that for each speaker, so you'll need a pretty efficient sub if you've got a sealed box.
If the box is sealed then I've had good results with Kicker Comps, MTX Thunders and Polk MMs. Currently running a Polk 12" in my car now and really like it. Got a Kicker L5 in my truck but like the Polk more (smoother, better SQ).
My equipment list is here. Playstation Network ID = jmii ...that's JM roman numeral 2
JMII is offline
post #3 of 8 Old 03-04-2011, 08:26 AM - Thread Starter
GaigeK's Avatar
So given that information can you send me a link to subs your would recommend at the DVC 4 ohm rating? I am having trouble finding some I like.
Anything under $100 a sub.
GaigeK is offline
post #4 of 8 Old 03-04-2011, 08:40 AM - Thread Starter
GaigeK's Avatar
GaigeK is offline
post #5 of 8 Old 03-04-2011, 08:54 AM
JMII's Avatar
http://www.sonicelectronix.com/item_...TR4512-44.html
JMII is offline
post #6 of 8 Old 03-04-2011, 09:07 AM - Thread Starter
GaigeK's Avatar
Those are 250 watt RMS. Is that ok??
GaigeK is offline
post #7 of 8 Old 03-07-2011, 09:51 AM
JMII's Avatar
What is your amp rated when bridged into a 4 ohm load? What size fuse? Wattage = volts x amps, so some quick math will tell you the most your amp can really push. Based on the specs you posted I guessed 300-450 RMS watts, divided by two and you'll be perfect.
JMII is offline
post #8 of 8 Old 03-07-2011, 10:38 AM
AK_47's Avatar
FYI before you buy checkout www.vminnovations.com's prices on 12-inch subwoofers. VMI's prices are the lowest online and all orders are delivered in 2-3 days for FREE.
Here is a pair of decent subs for less than $50 - HFI12D4
Use the coupon VMSAVE10 to take out additional 10%.
AK_47 is offline
Reply Car Audio, Video, and Nav
