Thoughts on Kenwood KDC-X794 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-19-2011, 10:04 AM - Thread Starter
EndersShadow's Avatar
Quoted: 507 Post(s)
Liked: 850
I am looking for some advice on if I should upgrade my head unit or not. Currently I am running a Kenwood KDC-MP438U cd player. It works with most IPod's, has an Auxiliary port, and does most of what I need. However I am looking at getting a Kenwood X794 head unit which basically would just add time alignment and a better EQ system from what I can tell. But is it worth the 160+ to get the new head unit?
The rest of my gear is getting upgraded as well. Right now I blew a rear crossover on my db6501's so I am running just my fronts bridged off the MTX Thunder Elite 404. I am still running my JL Slash 250/1 for my Treo TE sub.
Currently my fronts and rears are Polk db6501 components. The rear's are disconnected since I blew a crossover on my passenger rear. I plan to order the replacement part from Polk, but am debating re-connecting them to the system at all. I might connect them to the head unit just so that's done for when I sell the car.
I will be moving from the MTX TE404 which only lets you specify a high pass or low pass via a button which auto sets the crossovers to a Sundown 125.2. This amp lets you manually set the xover's for the channels. While it is a 2 channel amp, I can later on run all 4 pair of speakers from it, but would only be getting 80 watts. But with the ability to crossover the fronts and rears (both are 6.5's w/ a separate tweeter) I would probably be fine since I can tweak them better. To start with however I plan to run just my front components off of them. I need to set the gain a bit lower since the speakers are rated for 100 wpc continuous and sending 125 might blow them.
On the sub side I am moving from my JL Slash 250/1 to a Sundown 1200D. This amp is rated 1 ohm stable so I can get a massive amount of juice from it later on if I decide to add another sub. My Treo TE sub is a dual 4 ohm sub so we are going to wire it to present a 2 ohm load to the amp so I can get ~700 watts from it. The sub is also rated at only 500 watts max so we will be setting the gain a bit low on this as well. We have to wire the sub for 2 ohms as @ 4 ohms you only get 325 watts.
So given the gear I am getting, do you think it's worth buying a new head unit for basically just time alignment and the ability to set the crossovers from the head unit rather than the amps? All comments and questions welcomed and appreciated.
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #2 of 2 Old 04-19-2011, 03:11 PM - Thread Starter
Quoted: 507 Post(s)
Liked: 850
So after some discussion with the guys at the shop I think I am going to go ahead and order it. I will just not get the 4 channel amp for now and go with a good 2 channel to make up the difference in cost.
Reply Car Audio, Video, and Nav
