Stuck on "Loading..." - Clarion + Sirius - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-30-2011, 09:53 AM - Thread Starter
motocrossmann's Avatar
My new Clarion CZ501 is paired with a Sirius SCC1 tuner. It had been working fine for about 2 weeks. Now when I power on the radio and select the Sirius tuner, I just get "Loading...". Most of the time it will never connect. If I remove the faceplate and reattach, I have about a 50/50 chance of it working again. I have tried pressing the reset button on the receiver, that works for about 1 week, then I'm back to "Loading...".
Ideas? Ideas of where to go to get support? Clarion's support site is worthless.
motocrossmann is offline
post #2 of 8 Old 07-03-2011, 05:33 AM
charlesj123's Avatar
That I known issue with 2011 models, call Clarion. No firmware poted?
Charles
charlesj123 is offline
post #3 of 8 Old 07-04-2011, 05:46 AM
musse's Avatar
Rewrite firmwave. I bet it will help
musse is offline
post #4 of 8 Old 07-14-2011, 03:00 PM
sharks_me's Avatar
clarion was not a wise choice mate
sharks_me is offline
post #5 of 8 Old 08-15-2011, 04:19 PM - Thread Starter
Charles
Well there is firmware posted, but the notes do not mention fixing anything to do with Sirius. I'll give it a try and see what happens...
post #6 of 8 Old 08-23-2011, 01:03 AM
yawaraf's Avatar
Any luck solving this issue? It is happening to me too. What Firmware is your Clarion?
Sometimes it just says "Loading" when in Sirius mode and there is no music/sound. I can turn the unit OFF/ON once or twice and usually it begins playing again. Other times it doesn't work at all, then when I try it again later it works again. Also when I am under an overpass and the sirius satellite gets blocked out, the song title/channel disappear and "LOADING" appears, when reception is reestablished the music returns but the title/channel do not come back (just "LOADING") usually turning the unit on/off fixes this.
yawaraf is offline
post #7 of 8 Old 08-31-2011, 05:58 PM - Thread Starter
Well that doesn't sound exactly my issue (the part about losing reception & then reestablishing it), but I did flash my CZ501 firmware with both files posted on the Clarion site. I did this about two weeks ago, and have not had the same issue since. Fingers crossed!!!! Sorry I can't find the paper I wrote down the old firmware numbers on.
post #8 of 8 Old 11-03-2011, 06:49 PM
batman0730's Avatar
I'm still having this "Loading" issue. I've found I can regain temporary functionality by resetting the clarion, although it's random for how long that lasts (1 day - 1 month).
batman0730 is offline
Reply Car Audio, Video, and Nav
