Car dash cam .... - AVS Forum | Home Theater Discussions And Reviews
Old 07-28-2011, 10:06 PM - Thread Starter
HiDef360's Avatar
Looking to buy a car dash camera. Which do you recommend ?
Prefer long record times at high quality. Easy to remove when not in car. If possible tilt/turn features.
HiDef360 is offline
Old 08-09-2011, 03:41 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
I have this one:
http://www.dod-tec.com/product.php?cat_1st=4&cat_2nd=6
I bought a pre-production one as a sample which has some bugs, but I think they have been resolved.
It is nice and small but takes a fairly good quality video, as good as any similarly priced dash camera.
Uses a micro SD card
Overlays GPS speed on to video
Breaks up files into short 1 min clips to avoid data loss when power is disconnected
Starts recording automatically
If you want something of even higher quality, then look into something like the Contour HD cameras. They're designed for recording sports like biking, skiing, etc.. but offer pretty good quality recording. No speed overlay, but they have a GPS model which records the GPS track including speed.
sebberry is offline
Old 08-30-2011, 11:42 PM - Thread Starter
HiDef360's Avatar
Thanks ill look into that one.
How is it for night recording ??
HiDef360 is offline
Old 08-30-2011, 11:56 PM - Thread Starter
HiDef360's Avatar
Just noticed some vids on the site.
Looks good. Cant find prices though...
HiDef360 is offline
Old 08-31-2011, 12:10 AM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
sebberry is offline
Old 08-31-2011, 12:13 AM - Thread Starter
HiDef360's Avatar
Just another question, can you swivel the cam left to right while its mounted or is it fixed forward ?? Looks like it can.
HiDef360 is offline
Old 08-31-2011, 12:25 AM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
It's fixed. It only moves up and down.
I didn't like the suction cup mount so I got a cable clamp (like this:http://www.kmstools.com/images/large...525UVB_LRG.jpg) and attached it to the arm that holds my rear view mirror to the window like this:
sebberry is offline
Old 08-31-2011, 12:39 AM - Thread Starter
HiDef360's Avatar
Nice! Looks out of sight that way. Thanks for the help.
HiDef360 is offline
Old 09-20-2011, 05:03 PM - Thread Starter
HiDef360's Avatar
Update:
Bought the GS600. Firmware 2.1.1 -KH
So far works great. Only problem so far is the videos don't playback in the software it comes with or with the websites updated version, which is also supposed to show your position on google maps while reviewing clips....still buggy I guess.
Still testing out different options to decide if ill keep this or return it for another brand.
Pic attached is in 1920x1080 resolution, can get wider FOV with 1280x720 resolution though. Screen cliped from wmp player while reviewing video.
HiDef360 is offline
Old 09-20-2011, 05:07 PM
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
Have you noticed in any of the videos the GPS showing a speed once you come to a stop? There's a lag between the displayed GPS speed and the actual vehicle speed of a few seconds with mine.
sebberry is offline
Old 09-20-2011, 11:55 PM - Thread Starter
HiDef360's Avatar
Ya I noticed that but its like 1km/h at most for me. Im ok with that...for now.
HiDef360 is offline
Old 06-04-2013, 04:14 AM
MorrenCraige's Avatar
My is this one http://www.szswill.com/car-camera-hd/car-dash-camera-d310.html, purchase in this April.
It is HD720P with GPS navigation, very easy installation just like all other dash cameras in the markets.
I think currently no dash cameras have Pan/Tilt function, it is not CCTV camera system smile.gifsmile.gif
MorrenCraige is offline
