Swap the optical drive in a Kenwood DNX7100 - AVS Forum | Home Theater Discussions And Reviews
Old 10-06-2011, 01:15 PM - Thread Starter
SecretSpy711's Avatar
Has anyone ever done this? I bought my vehicle used with this double-DIN unit already installed. I took it out of the dash with the intention of cleaning the slot-loading drive because it has trouble ejecting discs, but it may be easier to just replace the drive within the unit.
Anyone have experience with this? Can I just buy another slot-loader DVD drive (SATA or IDE?) and stick it in there? I've almost got it taken apart enough to get the drive out, but I think there's another couple of screws holding onto it somewhere.
SecretSpy711 is offline
Old 10-06-2011, 03:05 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
odds are it is not a compatible unit with a computer optical drive. Not sure if Kenwood has a service similar to alpine's repair. You would have to get a hold of KENWOODS CUSTOMER SERVICE TO FIND OUT.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Old 10-09-2011, 12:37 PM - Thread Starter
Can you tell from these pictures whether it's compatible or not? the DVD unit itself says DVS-8530V
Old 10-10-2011, 09:11 AM - Thread Starter
so you're right, it's not compatible. But I learned a few things along the way... for example, a new DVD unit from Kenwood is $207 Does anyone have a Kenwood unit that contains a DVD player that they want to get rid of?
The other option is to open up the drive itself and clean it, or have it cleaned by a Kenwood service center, but that makes me a little nervous...
Old 10-10-2011, 11:19 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
I would say it boils down to cost... The new drive from Kenwood is to expensive. For another ~100 bucks you could get a whole new unit.
Get an estimate from Kenwood on a cleaning.
If it approaches 80 bucks... Or higher, I might consider a new head unit. It starts getting into the range of spending money on a used piece of automotive stereo equipment. It comes down to how much do you want to spend...
XBL-Steelhouse1
cubdenno is offline
Old 11-14-2011, 08:23 PM
pbarone_iv's Avatar
i may be way off here but would you be interested in selling the dvd drive out of your dnx 7100? i just purchased the unit from a guy off craigslist only to get it home and find out it is broken.... ive been had. anyway, i took it all apart and found the slider drive gear inside of the dvd drive broken. i am trying to find that gear but i hiiigghhhllyy doubt someone will just have a shelf off them ready to be sold. i could be completelty wrong though. back to the point... i need the gear so i was wondering if youd consider selling either your whole head unit or maybe even just the dvd drive?
shoot me an e-mail at pbarone_iv@hotmail.com if you dont mind, i may not see the response on here fast enough.
thanks
pbarone_iv is offline
Old 11-14-2011, 09:24 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
CD is dead. This is ur opportunity to move to a 16gig thumbdrive.
MrBobb is offline
Old 11-15-2011, 09:04 AM
pbarone_iv's Avatar
Cd may be dead....but the rest of the headunit and dvds are not dead. I would use the SD a lot or Ian cables to watch stuff any other way but the unit won't close without a functioning dvd drive ....thus not allowing use of any of the other features
Old 08-16-2013, 12:17 AM
Carnivore's Avatar
I know this is an old thread and the OP is probably long gone, but I found the photos quite helpful in swapping out my DNX7100 optical drive so I thought I would add to it to help anyone else in the same boat.
The original optical drive DVS-8530V has been discontinued. Kenwood's official parts source, Pacific Parts, indicates the replacement part number is 880A69-2697-78. Someone on Ebay was selling a bunch of these so I ordered one and it did NOT work despite PacParts claiming it would. He was kind enough to exchange it for another one which also did not work. The drive had the same form factor but there's a difference in the internal electronics. A lot of the functionality of the head unit seems to depend on the electronics in that drive so without it I lost most touch screen controls and it pretty much rendered the unit useless.
Luckily there's a solution. I was able to swap the PC board between the two drive units since the mechanical portion between them is identical, and the mechanics were all that was wrong with my original drive. 5 screws attach the bottom cover of the drive casing, and the PCB is easliy acccessible, held in place by 1 screw. You need to detach 2 ribbon cables which are held in place by flip down locking clips. The screws are very small and you need to pay close attention to how everything is seated so you can reassemble it the same way. It's a job for someone who is pretty technically inclined.
As for the head unit you need to pull the power plugs or you risk blowing a fuse even with the ignition off because the ribbon cables carry constant voltage. Remove the top cover and then remove the screws from the rear rail holding the drive down (but not the front rail). You need to remove the plastic brackets on the side that hold the screen tilt mechanism in place (and pay close attention to how the guides work so you understand how to replace them). Then you need to pull (hard) on the tilt screen rails to extend them out of the chassis so you can manually flip the screen down and access the screws holding the trim panel behind it. Remove the green clamp holding down the ribbon cable, it's held in place by 2 tiny screws. Disconnect the ribbon cable which is held in place on the back of the screen by a flip-down locking clip - hint, flip it up from the rear. Remove 6 screws holding the plastic trim behind the screen in place. Watch out for a small metal bracket behind that trim that may fall out of the chassis when you remove it. Then take out the remaining 2 screws holding the optical drive on the front of the chassis. Now you can flip the drive up and over to the right so you're looking at the bottom of it (see photos earlier in the thread) and detach the ribbon cable, again held in place by a locking clip. Now you can attach that ribbon cable to the new drive. Reassembly is pretty much the reverse.
Again this project requires a lot of disassembly, small parts, and a good understanding of how things fit together so it's not for the faint of heart. I didn't realize what I was getting into when I bought the updated "replacement" part on Ebay but I can now play discs again so maybe it was worth it. Good luck.
Carnivore is offline
