Pioneer x930bt or Clarion NX502bt - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-11-2011, 05:25 PM - Thread Starter
Thumper1279's Avatar
Ok so im having some trouble picking out what unit i want
i like the pioneer because it streams bluetooth Audio for ipod and also for the phone
i think the Clarion Does the same also
But not sure how the map updates on the 2 car i know kenwood is good cause they have garmine wich updates maps yearly
does anyone know how often pioneer or Clarion Come out with new map updates for there navigation units
also i know the Clarion all i need to do is ground the Parking break i belive so that i can use the navigation options whyll not in park
the Pioneer is much more Difficult in involves altering the actually harness wich i already have a car that is going to be temperamental with the Harness i have heard that sometimes you can mess up the system and get muffled noise if you mess with the GMOS-06 harness that i need to use for my Cadillac Seville 2000 with bose
so im thinking id rather have a unit that just needs a simple ground instead of the repining of some of the wires for the pioneer system
any help here would be great
also is there a forum specificly for clarion does anyone know i have been on the avic forum for the pioneer but not sure if that is a forum for the clarion units thanks
Thumper1279 is offline
post #2 of 7 Old 10-12-2011, 11:46 AM
BlackwaterStout's Avatar
I'm kind of in the same boat. Except I'm an android user. I'd like to have access to the Pandora function of the X930BT but I'm under the impression it will only work with iPhone.
As popular as Android has gotten I'd think Pioneer would make the 930BT android compatable.
BlackwaterStout is offline
post #3 of 7 Old 10-12-2011, 03:46 PM - Thread Starter
i think they are have searched on youtube there might be something on there about it
post #4 of 7 Old 10-13-2011, 05:07 AM
I searched but couldn't find anything stating that the X930BT would work with Android (other than standard bluetooth). I'd like to be able to stream my Pandora stations through the headunit.
I sent Pioneer and email asking them for clarification but as usual they haven't returned it yet.
post #5 of 7 Old 10-13-2011, 06:30 PM - Thread Starter
i think some are using there blackberrys for it so im not sure why it would not work with your android you might consider going into a best buy that has the unit set up on display and see if you can get it to work and test it out
post #6 of 7 Old 02-10-2012, 10:32 AM
joepaiii's Avatar
Looks like the spring 2012 940 model will support android. It is on pioneers web site.
joepaiii is online now
post #7 of 7 Old 02-20-2012, 09:37 AM
Aaronco2's Avatar
I have had this deck for about 3 weeks and love it. Does everything really well. I don't use the pandora stuff as its not avail in Canada. Not a worry for me, I'm addicted to my BB anyway
gps is great and very adaptive. BT is really clear and easy to connect. Sound (most importantly) is Fantastic!
only cons are maybe I wish the screen was a little more responsive, but could be I still need a little more learning curve.
Hope this helps.
Aaronco2 is offline
Reply Car Audio, Video, and Nav
