Kenwood Dnx7320 - AVS Forum | Home Theater Discussions And Reviews
Old 12-06-2011, 02:02 AM - Thread Starter
freemanteo's Avatar
My kenwood dnx7320 garmin gps is stuck at the splash screen, rest of the unit works great. I went to kenwood and they said they cant update it. They ask me to take it out n send to them for service, they said its motherboard. May cost $200++. I scoured google and not much is discussed about this model. Does it have the mini usb port at the back? Is it possible to update firmware using a burned cd or install igo? Or a safe boot? Any help appreciated. Thanks!
freemanteo is offline
Old 07-13-2012, 07:55 PM
Scarrab55's Avatar
Mine did the same thing. $150 to pull it out of the car. $600 to fix the NAV unit. $200 to replace in the car.
You can buy new units on ebay for $500.
Scarrab55 is offline
