Subwoofer question - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 12-09-2011, 11:38 AM - Thread Starter
ranger91's Avatar
my sub will handle 250RMS and 1000 PEAK..the amp bridged if i read right is 600 watts...im assuming thats not 600RMS...what RMS would that be?
ranger91 is offline
post #32 of 34 Old 12-09-2011, 11:53 AM - Thread Starter
ranger91's Avatar
found it..for that particular amp the RMS is 179 per channel...which still have no idea what the actual RMS will be when it is bridged.
ranger91 is offline
post #33 of 34 Old 12-09-2011, 12:04 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
I take the RMS as a continuous readin. Figure on 600 watts. You will be fine.
Two things destroy subs.
Thermal power-feeding continuous amounts of current. Usually music will never destroy a speaker unless you are just pouring the power to it. As an example I run 8" midbass drivers with an 80 watt power rating. I feed them 225wpc and they have been happy for 4 years. Remember that I need a front end to keep up with 145+db's of bass.
Mechanical limits- this is all about how much Xmax your sub has and not hitting Xmech. in all honesty, the enclosure will most determine what is going to happen and how much power you can apply.
Small sealed boxes can take a ton of power. Large sealed reduces power capacity
ported enclosure designed correctly increase the power capacity up to it's thermal limits, but elow tuning the woofer unloads and you can get damage.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #34 of 34 Old 12-09-2011, 08:27 PM - Thread Starter
ranger91's Avatar
got the hamp hooked up...sounds way better...but now i need to focus on the box...i think im still leaving alot on the table.
ranger91 is offline
Reply Car Audio, Video, and Nav
