Ford F150 Sony Nav - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-10-2012, 02:58 PM - Thread Starter
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Hey gang,
I have a Ford F150 Platinum and I have the Sony Nav with the 700 watt sound system which it also has a sub. It sounds ok, but I would like to make some changes. I thought about changing out the tweeters in the frames around the windshield, but I would really like to put a new powered sub in. I have read that some guys are using polyfill to make the stock sub sound better, but I am looking for a little bit deeper bass. My question is, can I change out the factory sub and still pair it to the Sony Nav? I have seen some custom subs that fit the F150, but not sure about the wiring aspect. Thanks for any info.
Reefdvr27 is offline
post #2 of 4 Old 04-10-2012, 09:13 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
If you can pull the factory subwoofer and determine its coil configuration, you can then better determine your options. Find out if its 8 ohm, 4 ohm, 2 ohm 1 ohm etc... Then try matching another sub to that.
Research Hoffman's Iron Law. Should give you a better understanding of what you are up against.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 4 Old 04-12-2012, 01:52 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1038
Thanks for the feedback. I was looking around today and I found this > http://www.f150forum.com/f38/2009-f1...gation-112650/
post #4 of 4 Old 11-03-2014, 08:33 PM
Liked: 0
Failed Sony sound system in F150 truck
I am trying to help out a friend who has an F150 ford truck with the high end Sony sound system. I was reading about the problems others in this forum were experiencing, none were exactly the same as my friend's. I believe that he has a bad amplifier module. This module is located under the center console between the front bucket seats. I have a copy of the radio system schematic (from a mechanic friend who has the Mitchell maint, system). If any of you would like to have a copy of these drawings, I would be happy to email you a set. Contact me at the email associated with my handle, technogeezer....
technogeezer is offline
Reply Car Audio, Video, and Nav
