So who makes the best modern small enclosure sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-26-2012, 11:09 AM - Thread Starter
Administrator
Administrator
Mike Lang's Avatar
Quoted: 1087 Post(s)
Liked: 826
I have a "vintage" Kicker Solobaric 12" sub in the recommended .66 c.f. sealed enclosure (& 500 watt mono amp) and it's been flawless since the late 90's. It's now starting to sound funky like clipping/distortion and rather than diagnose it, it's time for something new. However I want to stay with something similarly small as trunk space is important.
Who's making the best bank for the buck sub for an enclosure under 1 c.f.? I'd probably get a new amp as well. It looks like I can get a new Kicker L7 & 1 c.f. sealed enclosure along with something like a Hifonics 750 watt amp for around $500 but I'm looong out of the car audio loop so I'm wondering what might blow this away for less money.
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #2 of 5 Old 04-26-2012, 02:39 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
Credence still makes the original "Solobaric" subs. They made them for Stillwater. So I would give them a look.
Image dynamics works well in a small sealed enclosure
Dayton HO series works well but you might consider porting that thing as they realy shine in small ported. They sound very fine doing it.
I would suggest avoiding the L7 in small sealed. I have seen very little success going that route.
Amplification is cheap now days. A mono Class D amp can be had for under 200 bucks in the power class you are looking at. JBL makes a quality product and their factory refurbs are a fantastic deal. I bought my sons 2 1500 watt sub amps as factory refurbs and he has been abusing them for the last 2 years. If you have a preference for brand or aesthetics look for that. I like the plain black amplifier. If you like more flash, I would have a hard time recommending something.
I have had fantastic luck with Sundown audio. They are a boutique brand that has catered to the SPL crowd but they just happen to make a dang good product. I tend to work on several systems a year as a hobby so if you have a specific brand set of questions, I can try to answer.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 5 Old 04-28-2012, 01:56 PM
Gary McCoy's Avatar
Quoted: 140 Post(s)
Liked: 124
10 years and still in production: The Infinity Basslink. It's an intergrated powered sub of about 0.84 cubic feet and 200 watts rms power. It has a "servobaric" design with one active and one drone 10" speakers. The active driver has a feedback winding for the amp which results in extremely low distortion. Typical subwoofer driver distortion is 3-5%, which kinda renders the difference between an amp with 0.001% distortion and 0.1% a moot point. But with the active servo design reducing distortion, the Basslink has less than 0.3% total distortion at full volume, which is 1/10th of the typical amp/driver combination.
I'm a believer, I have bought 3 BassLinks so far.
Gary McCoy
The United States Constitution ©1791. All Rights Reserved.
Gary McCoy is offline
post #4 of 5 Old 04-30-2012, 02:12 PM
JMII's Avatar
Along the lines of what cubdenno said: Image Dynamic does well in small sealed as does Polk's MM line (which I've got in my 350Z). I've got a Kicker L5 sealed in my truck and its never really impressed me, they tend to do better ported and with lots of power.
My equipment list is here. Playstation Network ID = jmii ...that's JM roman numeral 2
JMII is offline
post #5 of 5 Old 05-03-2012, 12:55 PM - Thread Starter
Administrator
Administrator
Mike Lang's Avatar
Liked: 826
Thanks all.
I ended up going with an Alpine 12" Type-R in a 1.0 c.f. sealed box running 900 watts from a Hifonics Brutus BRZ1200.1D D-Class Mono Block.
It takes up a little more space but sounds much cleaner.
Reply Car Audio, Video, and Nav
