FM Transmitter Hum - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-15-2012, 04:50 PM - Thread Starter
Kleve13's Avatar
I have an FM Transmitter that plugs into the cigarette lighter in the front dash. I use my Android phone to play the music through the transmitter, but whenever my phone is charging in the car (I have tried both the front and rear cigarette lighter), I get a loud hum in the background. It stops as soon as I unplug the phone. I assume that the power going to the phone is causing the issue, but is there any way to stop this from happening?
K13
Kleve13 is offline
post #2 of 3 Old 07-16-2012, 06:41 AM
ShowMeCablesDrew's Avatar
It sounds like you have a ground loop.
You may want to try a ground loops Isolator
http://www.amazon.com/PAC-Ground-Isolator-3-5-Applications/dp/B001EAQTRI/ref=sr_1_1?ie=UTF8&qid=1342442327&sr=8-1&keywords=ground+loop+isolator
These do an OK job of knocking out the hum.
ShowMeCablesDrew is offline
post #3 of 3 Old 07-16-2012, 12:28 PM - Thread Starter
Kleve13's Avatar
Yep, this looks like exactly what I need. Thanks for the help.
Kleve13 is offline
Reply Car Audio, Video, and Nav
