Subwoofer for SUV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-06-2012, 10:13 PM - Thread Starter
Subjga's Avatar
I'd like to add a subwoofer for a Toyota Highlander, somewhere in the back, without sacrificing cargo/hauling space.
Anyone do something like this? What size is needed for an SUV?
For reference, I have a custom built 15" Sub for HT, but I heard you can get by with much smaller for car audio. Thanks!
Subjga is offline
post #2 of 4 Old 08-10-2012, 03:57 PM
Skunkie's Avatar
You could get by with a pair of 12 inch subs if you really wanted too or you could go single 12, if your not looking for something that will knock the car next door over onto it's roof, you might consider a mid range 10 inch sub.
Just make sure you match your ratings and make sure you can supply enough power for your setup.
Skunkie is offline
post #3 of 4 Old 08-12-2012, 07:21 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
budget?
listening preferences and performance expectations?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #4 of 4 Old 08-17-2012, 11:58 AM
Mark the Red's Avatar
SUV's get a big gain in bass due to its cavernous nature. A single 10" would be fine.
I have a 10": Dayton HO Reference sub 1.0 cu.ft ported to 29 Hz.
Here is a great diy box designed for the Titanic sub:
http://www.diysoundgroup.com/1-25-sub-flat-pack.html
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-414
Supply tons of power and it will sound great.
Mark the Red is offline
Reply Car Audio, Video, and Nav
