Wires connecting amplifier and speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-13-2012, 08:06 PM - Thread Starter
LuV2SPD's Avatar
I assume my car has original speaker wires that are connected to my front and rear speakers. Do I need to buy new speaker wires or I can use the originals? Also does it make a big difference to buy 14 gauge speaker wires from crutchfield for better performance or it really makes no difference? Also to connect a 4 channel amp to power do I need to buy one power cable? I'm seeing only for 2 channel amps and it says for 4 channel you need to buy additional cables.
LuV2SPD is offline
post #2 of 3 Old 08-13-2012, 11:06 PM
cubdenno's Avatar
Quoted: 65 Post(s)
Liked: 90
Original head unit or did you put one in?
Anyway,
You CAN use the factory wiring. It can be a pain though. Couple of methods are to use the rear speaker wires to connect to the amp and then jumper to the front speaker wires in the dash . OR you can run speaker wires to the front in the dash and splice to the factory speaker wires.
16 gauge wire is probably going to be fine unless you are running kilowatts on a sub and the run is fairly long. Buying big speaker wire is generally a waste of cash. Also though going too small can be detrimental.
Depending on how you are using your amp will determine the number of cables.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 3 Old 08-19-2012, 11:07 AM - Thread Starter
LuV2SPD's Avatar
The installer did use the original rear speaker wires to connect the front speakers to the amp but did use a piece of stronger cable to actually connect to amplifier.
LuV2SPD is offline
Reply Car Audio, Video, and Nav
