TC Sounds LMS-R 12" sub with a Sundown 1200D amp (help me build my box) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 10-14-2012, 05:21 AM - Thread Starter
EndersShadow's Avatar
Quoted: 629 Post(s)
Liked: 951
So I had another thread a LONG time ago (here) about building a box for my Jetta.
I am needing to actually do that now. I am open to just about any suggestions within reason. I am planning on building a box that is ported, tuned to ~30 hz to give me the flattest response (looking for a musical sub here, not SPL driven ONLY). I want to keep port noise under 20-30 m/s peak. I am looking to build a box about 1.75 cubic feet. My trunk is about 36" wide x 39" long x 20" tall. I would take ~2 inches off each measurement just to make sure it fits in though so lets call the trunk 34" x 37" x 18"
Right now the outer dimensions I am thinking of are 28" W x 16" H x 12" L. The interior dimensions would actually be 26 x 14 x 9 as I plan on using 1" think pressure treated MDF and making the baffle double to hold the weight of the woofer.
My main trouble is using those dimensions to come up with a port that isnt longer than the box. Any help would be appreciated
Comments?
My Setup | FS: Salamander Synergy 303, Outlaw LFM-1 sub, Sanus UF22 Speaker Stands, Nintendo Wii
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #2 of 25 Old 10-14-2012, 05:45 AM
tundrSQ's Avatar
Slot port or round port?
1" mdf is overkill...i would use 3/4 and then double baffle...and use the slot port to help brace the box.
Tim
tundrSQ is offline
post #3 of 25 Old 10-14-2012, 05:47 AM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
Can do either, preference on the slot port as I have somewhat basic woodworking skills and I think a slotted port would be easier.
post #4 of 25 Old 10-14-2012, 06:39 AM
tundrSQ's Avatar
i agree slot port is the way to go...are you thinking something like this? And just need the proper dimensions? slot port.jpeg 71k .jpeg file
Name:	slot port.jpeg
Tim
tundrSQ is offline
post #5 of 25 Old 10-14-2012, 08:51 AM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
Kinda like that, but with the 12" off to the right side. The more I think about it, the more I want to make it stretch as wide as I can, as tall as I can and then make it as shallow as possible (need at least 7 1/2 inches for the sub alone). I would then take the amps mounted at the back of the seat and mount them on the inside the slot port to the woofer. The amps are 12" and 13 1/2" tall and each is 10" wide and 3 1/2" deep. So I need about 36" wide to fit all that. The hope is that I could make the box so that the amps end up mounting flush, so the woofer section would stick out another 4 inches than the rest of the box? So the box would kinda look like a capitol L. That making any kind of sense?
Kinda like this (forgive my rudimentary modeling skills
box.txt 1k .txt file
File Type: txt box.txt (669 Bytes, 130 views)
post #6 of 25 Old 10-14-2012, 09:45 AM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
30 hertz tune is not going to give a flat in car response. Due to cabin gain/transfer function with that sub, you are going to get a pretty huge bump of low end. For flat response, tuning lower is required to get the flat response or sealed. Do you have winisd? I would model your sub with an input of 800-900 watts to find the compromise of port vs port velocity that is doable. At that power amount try to be as close as possible to 20 m/s as possible. Even with that amp wired for a one ohm dcr due to box rise the power produced will be around 2/3s of rated.
The small enclosure size is going to make it difficult to keep low tuning and port size manageable.
I wil have to look at my computer when I get home and I will see if I have any designs that fit your criteria.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #7 of 25 Old 10-14-2012, 09:54 AM
tundrSQ's Avatar
why would he want a flat response? In fact if anything i would suggest tuning HIGHER not lower...and let the cabin gain make up the difference. I think i would shoot for a 38 or 41 hz tune...but thats just me.
Go over to DIYMA and search thru the threads to find a tune point for a trunk mounted sub in a car like yours.
Tim
tundrSQ is offline
post #8 of 25 Old 10-14-2012, 10:46 AM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
In his first post he said flat response.
Tuning higher will make it harder to blend the mid bass to the subs.
The higher you tune, the closer to the vehicle resonance you are. You then end up with a one note wonder/ fartbox. Great for spl not so much for sq which again, in his first post he said he was wanting.
As for diyma, they would not say tune higher for sq. been there for almost 6 years. In fact the true main guys who have not just joined in the last,three years would explain in great detail why tuning higher is going to suck for sq.
Car audio.com would agree with tuning higher. But that site is a sewer of bad info.
Give a look at mobilesoundscience.com. The guys who were with the original founder NP Dang (diyma ) started that site after Ant made diyma another car audio.com after he bought it.
XBL-Steelhouse1
cubdenno is offline
post #9 of 25 Old 10-14-2012, 12:24 PM
tundrSQ's Avatar
i think its possible to achieve SQ.....without striving for a flat freq response in the low end. I am not trying to get him to the point where he is a spl burp machine by any means....and maybe i am not used to people wanting their sub to play flat.... especially in this case where he has chosen to use a beastly sub and amp combination and a ported box.
Occasionally ...people don't say what they mean....and personally i would still do my search i suggested and see whats working for people.
Tim
tundrSQ is offline
post #10 of 25 Old 10-14-2012, 12:26 PM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
On my iPhone so will keep it short. Outer dimensions might be 36 wide x 17 tall x 14 deep on the woofer and 10 deep on the rest. I believe it will be approximately 2.5 cubes. Need to actually model it and will post later.
Thoughts?
post #11 of 25 Old 10-14-2012, 12:29 PM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
Also this might be helpful:
http://tcsounds.com/product/drivers/lms-r-driver/
post #12 of 25 Old 10-14-2012, 12:57 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
The nice thing is, if you have an eq, any peaks can be eq'd down. Otherwise, I would model a bit to at least get you an idea. JBL had a graph of the cabin gain of a bunch of vehicles. Look for that and you can have an idea of what you will see in car.
XBL-Steelhouse1
cubdenno is offline
post #13 of 25 Old 10-14-2012, 01:13 PM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
My Kenwood KDC-X794 has a 5 band PEQ as well as programmable crossovers and slopes.
I still plan to model it in WinISD when I get home and post how that looks. Can anyone tell me if the TC Sounds specs for the small ported box will work decent in my car?
post #14 of 25 Old 10-14-2012, 01:50 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
The 1.8 cu ft enclosure would work fine. Tuned low though. Just model a higher tuning point. I fell the port may be undersized especially with the power you will be running, but again modeling should show what's going to happen. Tuning higher will help that port length.
XBL-Steelhouse1
cubdenno is offline
post #15 of 25 Old 10-14-2012, 02:53 PM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
So you would go with the large ported 1.8 cubic feet tuned to 20 hz with a 70" port over the small ported 2.5 cubic foot tuned to 30 hz with a 31 inch port? Is the because you think it will give me a better frequency response than the 30 hz box?
post #16 of 25 Old 10-14-2012, 04:17 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
They have the box sizes swapped. It should be 1.8 tuned to 30 is the small box. Just check the port length for tuning.
XBL-Steelhouse1
cubdenno is offline
post #17 of 25 Old 10-15-2012, 01:55 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
how good are you at taking a design and adding/subtracting to make it work for you?
I have a truck design for a center console sub. Rear firing. Ported. for a 12.
1.85 cubic foot. I believe the tuning is higher for max thump. I honestly can't remember and my work PC does not run WinISD for some reason. Gobs of port area.
to adequately suit you, changing woofer location and adding a side to increase port length to lower tuning might have to be done. Let me know if you are interested.
XBL-Steelhouse1
cubdenno is offline
post #18 of 25 Old 10-15-2012, 03:42 PM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
Sure I am good to a point with that kinda stuff...
post #19 of 25 Old 10-15-2012, 04:02 PM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
Pm me an email address. I will send it tomorrow from work
XBL-Steelhouse1
cubdenno is offline
post #20 of 25 Old 10-15-2012, 05:59 PM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
PM sent
post #21 of 25 Old 10-17-2012, 06:51 AM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
Did you get the design?
Understand my quick sketch?
XBL-Steelhouse1
cubdenno is offline
post #22 of 25 Old 10-17-2012, 07:39 AM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
I got it and it makes sense. Just need to tweak the back of the box since my trunk is angled.
post #23 of 25 Old 10-17-2012, 09:18 AM
cubdenno's Avatar
Quoted: 74 Post(s)
Liked: 93
Ooof. That may cause some unforeseen effects.
Changing the geometry other than just port length will change a whole lot on the response of the sub and enclosure.
Just a heads up.
If you are needing a trapezoidal-ish enclosure than running round ports would be the way to go about that. Or order a design from Pete for your woofer.
XBL-Steelhouse1
cubdenno is offline
post #24 of 25 Old 10-17-2012, 09:28 AM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
Just a heads up.
Yeah I figured that frown.gif. I will take a look and I might just order a design myself. Depends on a couple different factors.
post #25 of 25 Old 10-24-2012, 03:51 AM - Thread Starter
Quoted: 629 Post(s)
Liked: 951
As happens, things change. In this case this entire project has been scrapped and I now need to sell the Sundown 1200D.
Reply Car Audio, Video, and Nav
