Lilmike Cinema t-6 as car sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-28-2012, 09:48 PM - Thread Starter
Shinyav's Avatar
Anyone have any opinions on using one of these as a car sub?
I am looking for a project and wanted to do a car sub for awhile.
However, I love my horn for my room and thought a sub in a car might work as well.
http://www.avsforum.com/t/1358033/lilmikes-cinema-t-6
It should be plenty loud in a car. What I am wondering is if the tuning of 30hz would be somewhat correct? The output plummets below the tuning.
Don't really know much about car subs so any and all input would be very helpful.
Shinyav is offline
post #2 of 4 Old 10-28-2012, 10:25 PM
cubdenno's Avatar
Quoted: 66 Post(s)
Liked: 90
Is this for a car?
If so, it should work fine. Very little info below 30 except in some dub step, dnb etc...
Plus it should go in car below 30 easy thanks to vehicle cabin gain. Think you get a lot of bass in a room. WAIT TILL YOU SEE WHAT YOU GET IN A VEHICLE CABIN.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 4 Old 10-28-2012, 10:33 PM - Thread Starter
Shinyav's Avatar
Yep for a car.
Plan on just running it from my stock radio and to a small car amp.
Just starting to mess around with car audio but am also planning on a new car soon so am not putting anything in not easily removed.
Thanks for the response.
Shinyav is offline
post #4 of 4 Old 11-09-2012, 12:23 PM
AndreasMergner's Avatar
What did you come up with? I just built an Autotuba which is a horn sub designed for a car. It is smaller than the F-6 at 13"x14"x32". I need to get an amp now and a new head unit before I give any impressions.
Current HT: HTPC-->Epson 5010 projector-->135" screen, BFM TLAHs x7 & THT
Build log: DIY rotary sub for contemporary HT in 100 year old house?
Andreas' Slow Rotary Sub build
AndreasMergner is offline
Reply Car Audio, Video, and Nav
