5 channel amplifier question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-03-2013, 05:48 PM - Thread Starter
ajstrider's Avatar
I had a friend ask me today about upgrading his car audio. He wants to get a 5 channel amplifier and use just four channels for now, with plans of adding the subwoofer on the fifth channel later on when he gets more money. I told him this should be no problem at all, and just wanted to double check with you all.
ajstrider is offline
post #2 of 3 Old 01-03-2013, 06:38 PM
cubdenno's Avatar
Quoted: 66 Post(s)
Liked: 90
No problem at all.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 3 Old 01-05-2013, 10:08 AM
gtpsuper24's Avatar
Liked: 99
It wouldn't be a problem other than you might limit yourself on what subwoofers you can get. I think the best and most future proof way would be to buy a 4 channel amp and then buy a mono amp when you decide on a subwoofer. That way you can buy the subwoofer you guys want and get a amp that would match up with it. Instead of trying to find a subwoofer that would match with your 5th amp channel which probably isn't going to put out much power.
gtpsuper24 is offline
Reply Car Audio, Video, and Nav
