2013 Ford Focus SE Hatchback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-02-2013, 02:01 PM - Thread Starter
a372556's Avatar
Hi,
I just bought a new Focus, looking to improve the factory sound a bit, thinking of adding a small sub. Is anyone aware of any custom sub enclosures for this car?
A
a372556 is offline
post #2 of 5 Old 02-02-2013, 07:35 PM
Fancy Shoes's Avatar
Improve the audio using Focal audio. I would use alpine amplifiers.
http://www.focal-america.com/products/
This stuff will be more amazing than adding a sub. especially if you stick with the K2 power speakers.
Fancy Shoes is offline
post #3 of 5 Old 02-02-2013, 08:29 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
Have not seen on especific to your car.
Good news is its a hatchback. A small sealed enclosure with an eight to ten inch sub will add a bunch .
Will not even take much power to give you a solid bump in the low end to add what the factory system is missing.
I would look at crutchfield.com an ddo a car specific search with the car options your has. I might have missed something.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #4 of 5 Old 02-02-2013, 09:50 PM
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
The focus is a pretty small car. I would check some of the local install shops. Some of them do custom fiberglass enclosures pretty cheap which actually conform to various shapes of the car.
Just an example:
bigbarney is offline
post #5 of 5 Old 02-04-2013, 06:28 PM
dictator92's Avatar
Ahh hatchback your in luck for bass you just stepped into the horn effect cabin gain vehicle
dictator92 is offline
Reply Car Audio, Video, and Nav
