JBL GTX 10" 450 watt questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-09-2013, 06:38 PM - Thread Starter
blazinworm's Avatar
I just got a JBL GTX 10" 450 watt rms subwoofer from the local pawn shop for $20. ive never owed a jbl and know nothing about them. this seems to be an older model as i have only found it on some canadian auction site when i googled it and thats it. any one have any experience with these and/or know if theyre any good or if i good a good deal. the guy on the canadian auction site wanted $100 for his so i figure thats a good sign.
heres a pic i found online that lookes like the same one
Also i currently have a type r 12" hooked up would adding a 10" be a good idea for better SQ. my logic is that a 12" for deeper boomy bass and a 10" for tighter bass but idk i could be thinkin about it all wrong
blazinworm is offline
post #2 of 4 Old 03-09-2013, 06:53 PM - Thread Starter
blazinworm's Avatar
oh and since i cant find any specs for this thing what would you guys suggest for an enclosure. ill be building a sealed enclosure for it but am trying to figure out the best size. im thinkin somewhere around a 1ft^3-1.5ft^3 but ive never had a 10" so idk
post #3 of 4 Old 03-10-2013, 05:53 AM
tundrSQ's Avatar
did you try google? i found the specs in about 5 seconds.. I also found out that it is unfortunately maybe not be a subwoofer...so tread lightly.
Freq response: 30Hz-500Hz
Amp. Power Range: 20W-500W
Continious Power Handling: 250W
Peak Power Handling: 450W
Voice Coil dia: 2,0" (51mm)
Nominal Impedance: 4 Ohms
Sensitivity@2.83V RMS@1M: 87dB
Driver Displacement: 0,09 cu.ft. (2,55l)
Thiele-Small Parameters:
Fs = 31Hz
Vas = 1,85 ft² (52,4l)
Qts = 0,43
Qes = 0,45
Qms = 7,55
Re = 3,3Ohms
Le = 0,6mH
Xmax = 0,480 in. (12,2mm)
Xpk = 0,866 in. (22mm)
Sd = 0,3724 Sq. Ft. (0,0346 Sq.M.)
Vd-linear = 0,000422 Cu. M.
Vd-peak = 0,000761 Cu. M.
Tim
tundrSQ is offline
post #4 of 4 Old 03-10-2013, 05:37 PM - Thread Starter
blazinworm's Avatar
ya i found those same specs i meant specs as far as suggested enclosure size by the manufacturer. what do you mean its not a subwoofer???
Reply Car Audio, Video, and Nav
