Problem with a Pioneer AVH-P4200DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-18-2013, 04:11 PM - Thread Starter
wooldog55's Avatar
I have had no problems with my AVH-P4200DVD that was hooked by a tech 2+years ago.I had it set to turn off when I stopped and removed the key. My battery went dead on my truck and when I replaced it and hooked up the power the radio went back to working as before, but won't turn off when the ignition is turned off. The unit stays on and I have to disconnect the neg terminal to keep from draining the battery. What changed so it won't turn off with the key?
wooldog55 is offline
post #2 of 2 Old 03-20-2013, 06:09 AM
bigbarney's Avatar
Quoted: 163 Post(s)
Liked: 60
Could be a lot of things. The most obvious though is that some memory somewhere got cleared. Check the HU and make sure ALL settings are back the way they were. Also check the truck. You don't mention the type of truck but the newer ones have some options to set the vehicle up to continue running accessories after the key is out. If the battery is out long enough all these options go back to the default settings.
Failing that, then disconnect the red wire off the back of the HU (while the HU is on and the key is out) and see if it now shuts off. If yes then the truck is the problem. If no then there is a problem with the HU.
bigbarney is offline
Reply Car Audio, Video, and Nav
