Bluetooth and Amp setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-23-2013, 06:37 AM - Thread Starter
Adio666's Avatar
Hi All,
I've joined this forum purely because i can't find the answer online anywhere (easily at least). I have had a Bluetooth Parrot system installed in my car for a while now which works fine until recently since i have installed a Sub and Amp in my car as well, and noticed that the Amp only picks up what is playing through the radio and not the Bluetooth system. The Parrot Bluetooth seems to use all the speakers in the car bar the Amp.
Does anyone know how to set the Parrot Bluetooth system up to go through the radio properly so the Amp picks it up. I use Spotify from my phone so it would be a pain if i had to burn loads of CD's just to listen to the music i want .
I can provide additional information if it helps
Adio666 is offline
post #2 of 6 Old 05-23-2013, 01:38 PM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Can you describe the install a little more in depth? Not concerned with the parrot.
How is the amp connected to the head unit? where/how does the amp get it's signal?
factory head unit? after market?
What type make/model/year of vehicle?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 6 Old 05-28-2013, 04:21 AM - Thread Starter
Adio666's Avatar
Hi,
Thanks for the reply.
The amp is connected to the head unit in the back with an RCA cable and is signalled in the back of the head unit as well with the signal wire.
The head unit is a Kenwood kdc 3021. And the car details are as follows: Vauxhall Corsa C year 2000
Adio666 is offline
post #4 of 6 Old 05-29-2013, 08:05 PM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Can you check and see if the amplifier is "ON" when it switches to the bluetooth? I am wondering if the remote turn on is either the power antenna lead or that when in bluetooth mode the amp remote turn on shuts off.
XBL-Steelhouse1
cubdenno is offline
post #5 of 6 Old 06-04-2013, 10:38 AM - Thread Starter
Adio666's Avatar
Hi,
The Signal wire from the Amp is connected to the radio, but i don't think the Parrot goes through the radio as it can be off when being played. I have had another look into it and i think it needs another wire that was sold separate from the kit to get an Amp connected through it. It is a Parrot MKi9100 if that helps.
Adio666 is offline
post #6 of 6 Old 06-04-2013, 01:39 PM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
did you check to see if the amp is "ON" when using the bluetooth device?
XBL-Steelhouse1
cubdenno is offline
Reply Car Audio, Video, and Nav
