What amp will suit my sub??? - AVS Forum | Home Theater Discussions And Reviews
Old 07-01-2013, 12:25 PM - Thread Starter
Jwilding2's Avatar
Hello, I am new to this forum and this is my first post, I have brought myself a double fusion box fitted with two pioneer 12" champion pro series 3000w subs, I haven't the slightest clue where to stary looking for an amp which would be most ideal, also i font really want to be spending through the teeth, any help would be grand cheers
Jwilding2 is offline
Old 07-01-2013, 01:37 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
We need a model number for the subs to determine coil configuration.
My next advice, would be to look at a mono amplifier.
A budget would help. Some people cringe at a 100 bucks some at a 1000.
Location is also helpful. A common US brand amp is no help if you live in the UK.
What are your performance goals. Are you just adding a bit of low end or are you trying to hit some serious SPL numbers?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is online now
Old 07-01-2013, 04:54 PM - Thread Starter
Jwilding2's Avatar
Ok thanks I shall look at the spec and get back, bassically looking to spend no more than 120, uk and really just want to get the best out of the sub I have as in shear BASE and vibration, being a total of 6k taking into consideration what it would really put out I would imagine rather loud still?? Thanks
Old 07-02-2013, 08:10 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
remember that subs put out decibels (a measure of sound pressure) you feed them watts (voltage times amperage)
And you feed about any sub 3000 watts and within a very short time you are melting a voice coil... eek.gif Thankfully most music is dynamic so the 3kw that the sub is rated to handle would be a short as in millisecond burst of power and the sub better be in the right box etc... But I will try to not over complicate things
120 euro?
Some specs on the box you bought would be nice. the enclosure is going to really dictate the end sound and quantity of bass you get.
Found this on Ebay UK
http://www.ebay.co.uk/itm/Phoenix-Gold-Xenon-1200-1-mono-amplifier-/251298021217?pt=UK_In_Car_Technology&hash=item3a82877f61#ht_425wt_1141
it's a bit more expensive but a real beast of an amp.
There are some real good amps but again, I need to know coil configuration of the subwoofers to best help you determine what amp.
XBL-Steelhouse1
