Using a double din stereo and a 1/2 din equalizer. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-04-2013, 03:02 PM - Thread Starter
Shakenblake12's Avatar
I am looking to upgrade my head unit in my car and i am also thinking about buying a equalizer. ( i will put links at the end of the post incase that is needed.) will i be able to put a double din and a 1/2 din in a 2004 ford explorer without doing any cutting out of my dash or anything? just simply buy a double din mount and put that and the equalizer in? is there any special mounts that are needed for doing so? Thanks for any help
Stereo: http://www.amazon.com/JVC-KW-HDR81BT-Double-DIN-receiver-Bluetooth/dp/B0079LGKYS/ref=sr_1_9?s=electronics&ie=UTF8&qid=1372974802&sr=1-9&keywords=double+din+car+stereo
Equalizer: http://www.amazon.com/Clarion-EQS746-Graphic-Equalizer-Crossover/dp/B000EZV3T8/ref=sr_1_1?s=car&ie=UTF8&qid=1372975274&sr=1-1&keywords=car+stereo+equalizer
Shakenblake12 is offline
post #2 of 2 Old 07-04-2013, 11:01 PM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
Short answer yes you will have problems
http://www.amazon.com/Pioneer-DEH-80PRS-Receiver-Crossover-Alignment/dp/B006Y44DAY/ref=sr_1_14?s=car&ie=UTF8&qid=1373003936&sr=1-14&keywords=Pioneer
This will do what you want and a bit more.
Or just choose a double din or go with a single din and the eq.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Reply Car Audio, Video, and Nav
