combining subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-06-2013, 09:59 PM - Thread Starter
taytay17's Avatar
I have 2 Rockford Fosgate HE2 10 inch 800 watt peak subs that are DVC. one is wearing down and the other is in perfect shape. i was considering replacing the one that is wearing down with another one. I am in need of suggestions on what i could replace it with as the same subs are quite pricy.
taytay17 is offline
post #2 of 4 Old 08-07-2013, 11:22 AM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
How is the old one wearing down? While yo can mix and match subs you will want to try to match the t/s parameters as close as you can. How much power are you applying?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 4 Old 08-08-2013, 08:28 AM - Thread Starter
taytay17's Avatar
the old one is hitting at a delayed frequency behind the "good" one. but what are t/s parameters? and I have a 800+ watt amp.
taytay17 is offline
post #4 of 4 Old 08-09-2013, 11:15 AM
cubdenno's Avatar
Quoted: 72 Post(s)
Liked: 93
HUH???? I have never seen anything like that.
Are you sure you have polarity hooked up correctly?
Take a AA battery. Place the positive speaker wires on the + of the battery and the negative speaker wires on the - of the battery.
Both cones should move out.
It almost sounds like you have either one wired out of phase, or have a coil of one wired out of phase on the old one.
Are they in a common chambered enclosure? (both subs share the same box with no divider) that can cause that effect visually.
XBL-Steelhouse1
cubdenno is offline
Reply Car Audio, Video, and Nav
