Pyle PLBT72G problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-18-2013, 10:37 PM - Thread Starter
Jeremy LaFave's Avatar
I recently installed the Pyle PLBT72G single din in-dash dvd player with gps. The gps and all audio works, however, when trying to play any video from dvd and usb it only plays audio or once in awhile from usb it gives the error of "invalid key." I am easily able to remove the unit and check wiring connections. Anyone have any ideas?
Jeremy LaFave is offline
post #2 of 5 Old 08-21-2013, 12:10 AM
Matthew Gurskis's Avatar
Connect the brown "Brake" wire to your black ground wire.
Jeremy LaFave likes this.
Matthew Gurskis is offline
post #3 of 5 Old 08-23-2013, 09:34 AM - Thread Starter
I will try that when I get the chance and let you know how it turns out. Thanks for your input.
post #4 of 5 Old 08-29-2013, 09:16 PM - Thread Starter
It worked, thanks.
post #5 of 5 Old 05-27-2014, 06:16 PM
Rorekofnol's Avatar
i just got mine and it will not save any changes that i make on it    i cant find out why this is happening  plz help
Rorekofnol is offline
Reply Car Audio, Video, and Nav
