Best 6.5" Coaxial Speaker for ~$120 a pair - Quality over Volume - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-21-2013, 12:25 PM - Thread Starter
spddy101's Avatar
Hi!
I'm new to car audio and just checked out some speakers at Best Buy. My favorites from what they had were the Polk DXI651 and the Alpine SPE-6000 with the Polk having the slight edge up on the Alpine with better clarity.
I'm looking for the best sounding speakers I can get. I'm not planning initially on having an amp or a sub so good bass would be nice but is not essential. How does the Polk and Alpine compare with what you've heard in the $80-$150 range? What recommendations do you have?
If it helps, I have a 2003 Honda Civic LX and I'm looking to put these in the doors.
spddy101 is offline
post #2 of 4 Old 08-21-2013, 01:24 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
Yeah the Alpine type S 6 1/2-6 3/4 speakers are hard to beat. For bass, the bigger the cone the better it usually produces bass. When installing, make sure to seal any large holes on the inner door skin (not water drain holes in the bottom) to give you better low end response.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 4 Old 08-21-2013, 02:33 PM - Thread Starter
spddy101's Avatar
hmm, interesting, I actually preferred the polk (sorry if my wording was a little confusing) over the alpine for the 6.5 in. but I loved the Alpine SPE-6090 (I'm putting 6"x9"s in the back) and didn't get a chance to hear the polk's 6x9s because they weren't at the store. Most of the detailed comparison between the two was done on a jazz female vocal song.
So the type S speakers are highly-regarded? Do you or anyone know about the sound of the DXI690? All recommendations and input are greatly appreciated.
spddy101 is offline
post #4 of 4 Old 08-22-2013, 08:35 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
Not familiar with the polks as far as listening. I have installed the Type S speakers and thought that for a car audio driver, it did very well. The new type R are even more amazing but well out of the budget. I am all for, if you like it, get it. pretty sure the polks will suit your needs as well as the Alpines.
XBL-Steelhouse1
cubdenno is offline
Reply Car Audio, Video, and Nav
