Over head monitor help needed !!! - AVS Forum | Home Theater Discussions And Reviews
Old 08-22-2013, 08:37 AM - Thread Starter
ramrod50000's Avatar
Vehicle : 2002 Ford Excursion
Head unit : Kenwood dnx8120
Ok have an issue that has been driving me nuts trying to figure out ! I originally had a Myron Davis rear over head monitor and console. Monitor got stolen when my vehicle was broken into at a local Costco. For the coat of the unit I didn't really care for the resolution on the original monitor. So I set out to search for a replacement monitor that would fit in the myron Davis console.(I like the close to factory appearance) After months of searching I finally found a replacement that would fit in the Myron Davis console. It was a off brand off of EBay. Price was right, $100. Now here's the problem besides the video RCA's it has 4 wire connections (12v power, accessory 12v, ground , and 12v door power) ok so I connect all 4 correctly and verified my feeds with a meter. Problem is unit will only work when the door is open. As soon as I close the door it shuts off . I have checked and triple checked all connections. Any ideas ???
Here's the unit I got:
http://item.mobileweb.ebay.com/viewitem?sbk=1&nav=SEARCH&itemId=120851552832
ramrod50000 is offline
