Anyone using a Pioneer AppRadio 3 SPH-DA210 with an iPhone4? - AVS Forum | Home Theater Discussions And Reviews
Old 09-22-2013, 08:29 PM - Thread Starter
IronHorse's Avatar
Thinking about getting a Double Din combo unit for my truck, and since I use an iPhone4 the Pioneer AppRadio line looks attractive on paper. Sounds like it mirrors your iPhone and displays your various apps on the HU's interactive touchscreen. I have to ask... is it PnP LOL? I'm willing to bet its not!
I need to be able to use the GPS and iPhone (hands-free) simultaneously, and it would be neat if my text actually appeared on the display. But long story short... I'd like to hear from actual owners who can list their pros/cons, installation gripes, problems with iPhone Apps not living up to their billing, which map/GPS setup are you using and why. I sometimes shuttle my grandkids around, so it would be nice to have that DVD player.
If not an AppRadio3, what else? I've looked at some Kenwoods and they are very nice.
• If God had intended man to watch TV 24/7, he would have given him Rabbit Ears •
Mitsubishi WD-65737 DLP • Yamaha HTR-5063 • Panasonic BDT210 BDPlayer • DirecTVDVR • Chromecast • AppleTV/XMBC • Comcast HD
Speakers • Towers Polk Audio Monitor60B II • CC Polk Audio CS1B II • Rear Surround Klipsch S10s • Sub Velodyne EQ Max 8"
IronHorse is offline
Old 09-24-2013, 08:16 AM
freescopesdad's Avatar
No answer for you, but I also have been looking to replace my AVH-P4400BH (no app mode) with the AppRadio3 just to get navigation and other available apps. I don't mind a bit of a learning curve, however all I have heard from others who have tried the unit is that it is buggy, many apps don't work as advertised, and Pioneer's support is poor to non-existent. I also am considering upgrading to a new iPhone 5C and IOS7, and I shudder to think what that will do. I will just have to wait, but I also am looking at the Kenwood DNX890HD navigation receiver.
Ron
freescopesdad is offline
Old 10-07-2013, 09:05 PM - Thread Starter
IronHorse's Avatar
Ron
Ron...
I bought the SPH-DA210 AppRadio3 from Amazon, and along with some techie friends attempted to install it in my 2001 Ford SVT Lightning pickup. First we had to pull the then-current Alpine single-din HU. Then we had to do some extensive surgery to the inside of the dash to allow the DD unit to be fitted. We got the radio wired in, GPS puck is mounted under the dash skin about 1/4" from the removable plastic "surfboard" thats just off center butt slightly on the PS. Every Lightning owner I know with DD/GPS puts the puck there and it works great.
So the radio has multiple jacks in the back and one of them is for the Pioneer CD-IU201N USB to 30-Pin Interface Cable, that plugs directly into my iPhone4 which is running IOS v.7.0.2 (iPhone5 uses a totally different cable). Apparently this onnection or handshake is a PITA to get going and the sun, moon, and stars must all be aligned for the handshake. My iPhone paired with the AR3 almost instantly, and I can stream music from my iTunes w/o a problem.
What is not working right now is acknowledging the AppRadio-specific Apps I have downloaded and installed; The Pioneer AppRadio App, which in turn leads you to Pioneer-Approved & Tested Apps. I also have CarMedia Player installed along with MotionX GPS, and Waze. So I tried calling Pioneer today several times, always busy or a recording saying they are closed during lunch (west coast). Finally gave up and emailed tech support and I outlined my problem and questions and received an acknowledgement that the email had been received and that they will contact me.
So, I'll wait to hear from Pioneer, and we'll see if its an easy fix. If not I'll bring it to a local installer that I know pretty well and have him do it, and I'll pay him to make it work. One of my friends with a Lightning has a 1st generation AppRadio in his truck, but he's running it through a jailbroken iPhone3... forget what IOS he's running. But it works just as advertised. One thing to keep in mind is that the only Apps that work are those Pioneer has tested and approved and are available through the Pioneer AppRadio App. There have been some issues with cables so I may have to return the USB-Apple 30-pin for another one.
If your contemplating a Double Din install, make sure you have not only your radio, but a auto-specific pigtail like those available from METRA, a Double Din bezel mounting kit that is vehicle specific, a micro-bypass for the parking brake if you want to allow video viewing at the HU, and of course... the correct USB-Apple cable.
All that being said, the Kenwood is an excellent choice for a DD unit with an iPhone. The model you mention is a good one. I have high hopes for the AppRadio 3, and will post up my progress.
Mike
Old 10-10-2013, 05:23 PM - Thread Starter
IronHorse's Avatar
Quick update: AppRadio now working. smile.gif Problem is that all AppRadios are preset to default to iPhone5 so you have to read the fine print and reconfigure the setup to talk to the iPhone4 models. Once that is done, it works. Still haven't hooked up my hands free phone microphone, have it halfway there, mike is mounted now snaking wire to HU, dash is out, will pull HU in the morning.
Old 03-05-2014, 05:24 PM
JoSchramm's Avatar
How did you reset your SPH-DA210 from default iphone 5 to iphone 4s?  We are having similar issues.  Bought at BestBuy, had Best Buy install and not getting any connection to apps.
JoSchramm is offline
Old 03-21-2014, 01:23 PM
williamvasport's Avatar
Hi you got to turn off in the home screen the speakers ... then it would be able to change to "others" the default iPhone av....now you can use an android phone and a iPhone 4 or 4s
hope it help
williamvasport is offline
Old 03-29-2014, 02:35 PM
ant845's Avatar
I'm having a lot of issues with my pioneer avh
4600 double din. I have an iphone 5s and none of the app radio apps are working. My phone is connect to the USB to lightning connector and then to the receivers USB.
This may not be the correct way. If anyone has any suggestions let me know.
Also does anyone know if the Siri eyes free can be activate by steering wheel control ???
ant845 is offline
