Not sure if amp matches subwoofer I'm interested in - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-30-2013, 10:59 PM - Thread Starter
Skeetin22's Avatar
Okay, let me begin by saying I have a Rockford Fosgate P1000-1bd amp. I'm looking at getting the Alpine type X 12 inch. Just one. Don't think there's any need for two and I would need another amp. My question is, are these two components compatible as far as ohms? Also with the amp that I have would I be supplying enough power to the sub? Thanks for any helpful input before I drop a lot of $$
Skeetin22 is offline
post #2 of 2 Old 11-01-2013, 09:12 AM
cubdenno's Avatar
Quoted: 67 Post(s)
Liked: 91
Need a it more information.
Make sure to find the lowest load the amp is designed to run. Ie: one ohm or two ohms.
Then to have access to that max power, you would then buy a dual voice coil sub.
For two ohms you want dual 4 ohm coils
For one ohm you want dual 2 ohm coils
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Reply Car Audio, Video, and Nav
