A little tuning help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-22-2013, 08:11 PM - Thread Starter
Noxdowne's Avatar
I bought a bassworx dual 12" ported box that has 1.65 cu ft or 46.7liters volume depending on your preference and it says is has tuning of 42hz.
For the box I have MB Quartz 304 and the specs are found in this PDF. http://www.mbquart.com/manuals/subwoofers/mb_quart_onyx_owc_subwoofer_manual.pdf
What would be a good frequency range to run for mid bass? Not looking for shake the ground sub effect. More drums and low guitar etc.
Any help would be appreciated
Jeff
Whether you think you can or think you can't...you're correct!
Henry Ford
Noxdowne is offline
post #2 of 8 Old 12-22-2013, 08:53 PM - Thread Starter
Noxdowne's Avatar
I'm going to change what I'm asking. I don't need 80hz and lower. What would be the frequency response of these speakers in that box? Could I run them 100-400?
Henry Ford
Noxdowne is offline
post #3 of 8 Old 12-24-2013, 09:01 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 82
You could try. Going to need active crossover capability somewhere.
Are you doing this in a car? If so what is going to take care of the under 100 hertz?
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #4 of 8 Old 12-24-2013, 11:33 AM - Thread Starter
Noxdowne's Avatar
I have 2 18's for sub duty. 20 8's for bass. Just wanting more drum punch, so I'm putting these on an unused channel on my mini dsp where I can tune the exact frequencies for just that. Power would be from one channel of an EP4000 amp. A total of 8 of these 12's to fill that void in my home theatre.
Because I'm using car subs and sub boxes I figured I'd ask the gurus in car audio smile.gif
Henry Ford
Noxdowne is offline
post #5 of 8 Old 12-24-2013, 05:25 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 82
No need to ask car guys. It's not the brand of woof, it's application.
I am wondering that with so many 8's (20 yikes!) you have some sort of cancellation going on. Something out of phase. Plus running the twelves mono, in the midbass to lower midrange, might also cause some issues.
Anyway, sure it could be done. Use some foam rubber to seal the port of the enclosure. Run them sealed.
XBL-Steelhouse1
cubdenno is offline
post #6 of 8 Old 12-28-2013, 11:09 AM - Thread Starter
Noxdowne's Avatar
Why do you recommend sealed?
Henry Ford
Noxdowne is offline
post #7 of 8 Old 12-29-2013, 05:54 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 82
Because you mentioned that you were wanting to run them 100-400. Since your enclosure is ported and tuned to 42 hertz, I was trying to eliminate any effect the enclosure might have on the overall frequency response if any.
XBL-Steelhouse1
cubdenno is offline
post #8 of 8 Old 12-30-2013, 08:42 AM - Thread Starter
Noxdowne's Avatar
Thank you for explaining that. I get it.
Henry Ford
Noxdowne is offline
Reply Car Audio, Video, and Nav
