Whats the difference between wiring a sub in parallel vs. Series? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-16-2014, 05:14 PM - Thread Starter
Bassssss's Avatar
I have two  four ohm Kicker CompVR 12's Dual Voice Coils. Also have a Pioneer Gm- D8601 monoblock amp. I looked at the wiring diagrams on the Kicker website and noticed that there is two ways to get them wired to 4 ohms. One way being series and the other parallel. Will there be any difference?
Whats the optimal way to wire them?
Link to diagrams: http://www.kicker.com/dvc_wiring
Link to amp:http://www.crutchfield.com/p_130GMD8601/Pioneer-GM-D8601.html
Link to Subs:http://www.crutchfield.com/p_2061CVR124/Kicker-10CVR124.html
Bassssss is offline
post #2 of 2 Old 01-17-2014, 08:21 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
If the kickers are dual voice coil and 4 ohms per coil,
Wire each sub series coil 1 to coil 2 for the sub per the diagram to achieve an 8 ohm load. Then wire to the amp
Do that per each sub and the amplifier will see 4 ohms
Each sub has it's coils series wired and then you are parallel wiring the subs to the amp.
DVC8ohmwiring.JPG 16k .JPG file
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
Reply Car Audio, Video, and Nav
