Replacement Speakers for 2012 Harley Davidson Street Glide - AVS Forum | Home Theater Discussions And Reviews
Old 05-26-2014, 08:49 AM - Thread Starter
LazarusIV's Avatar
Hey all!
My buddy has a 2012 HD Street Glide with the Boom Audio Amp upgrade and he needs replacement speakers for it. He found a set of Kicker speakers on Crutchfield.com and then he found another set on cycleaudio.com that he's a little iffy on. Basically, he's looking for a good set of speakers for his bike, so I thought I'd bring it to the brains and experience of the avsforums! Any help is appreciated, ladies and gentlemen!
LazarusIV is offline
Old 05-27-2014, 04:31 AM
DeLaw's Avatar
Try parts-express.com.
DeLaw is offline
Old 07-09-2014, 01:31 PM
Coach KG's Avatar
HD Forums has your answer
There is a ton of info on the hdforums: http://www.hdforums.com/forum/audio-systems-153/
Both Kickers & Polks have gotten mixed reviews on there. Most are critical of the Boom Audio speakers & amps.
Based on reading the threads and IM'ing HDForum members, here's a quick answer.....
Good = Infinity Kappa 62.11's
Better = Biketronics 7.1 Titans
Best = Focal 165-KRC
Replacing the stock speakers is easy on a 2012 SG. Remove seven T27 screws (google "removing street glide fairing" and there are plenty of good step-by-step videos).
If you/he decide to upgrade the amp, a cheap route is the Rockford Fosgate PBR 300x2 which is available on Amazon.
Have fun & good luck.
Video: Epson 5010 / SI Black Diamond G3 1.4 / Oppo BDP-103 / Darbee Darblet
Audio: Yamaha RX-A820 / Emotiva XPA-5, UPA-200/ B&W: CM9s, CMC2, CM7s / Seaton Submersive HP
Coach KG is offline
