Car stereo weird audio problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-15-2014, 10:15 AM - Thread Starter
Bizz28's Avatar
Question Car stereo weird audio problem
Hello everyone. I hope someone can help me or point me in the right direction. I just had an Alpine CDE-SXM145BT, Hifonics Amp and Subwoofers installed into my '01 Chevy Impala and I'm having a weird issue where I'm getting full sound from my car speakers when I choose the "Tuner" (radio) source but no sound from my speakers through any other source such as "AUX", "Bluetooth" or even just a reg CD. What could be the problem? The installer looked confused and didn't know how to fix the issue and said "if theres sound coming from the "Tuner" source theres no reason the other sources shouldn't work." Hmm, If there's sound coming from one source why would the other sources not work?? (I can hear bass from the subs with other sources but no audio from the reg speakers) Any help is greatly appreciated!
Bizz28 is offline
post #2 of 4 Old 09-03-2014, 08:27 PM
Liked: 0
Same Issue
Did you ever get an answer to this issue and get it solved? I just hooked the same tuner up and I have the exact same issue.
dlapore is offline
post #3 of 4 Old 09-05-2014, 11:19 AM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
Check and make sure you have connected the amp turn on line to the correct output wire from the head unit. My bet is you connected the remote turn on to the power antenna wire (blue) instead of the remote turn on wire (blue/white stripe).
Works great with the tuner, but shuts the amplifiers off when you switch to a different source.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #4 of 4 Old 10-30-2014, 03:45 PM
Quoted: 14 Post(s)
Liked: 6
This
roland13 is online now
Reply Car Audio, Video, and Nav
