2015 Fit Audio System and HondaLink - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-19-2014, 10:15 PM - Thread Starter
jupiter_joe's Avatar
Hi,
Not sure if/when there might be any information on this - but thought I would try to see if anyone might be looking into this possibility.
I have seen where the new 2015 Fit and the new Civic are using a 7" display that can integrate with the iPhone or iPad to offer some nice features.
One of the features actually allows you to Mirror the iPhone onto the display. However, when the car is put into Drive - the display is deactivated as a "safety" feature. I would rather use Google Maps via this feature. So hoping someone out there may learn of or know of a way to bypass the lockout feature when the car is put into Drive.
Thanks....
jupiter_joe is offline
Reply Car Audio, Video, and Nav
2014 honda civic , 2015 honda fit , disabling screen blackout , hondalink
