Bluetooth adapter and cdxm60ui - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-18-2014, 01:58 AM - Thread Starter
Liked: 0
Hi, I have a Sony receiver (cdxm60ui) that is compatible with Iphone\itouch via USB connection. I'm wondering if I can use a bluetooth adapter to the stereo instead of the cable. Any feedback or suggestions are appreciated. Thanks.
Sam Elliott is offline
post #2 of 2 Old 09-27-2014, 03:41 AM
hotrod351's Avatar
Quoted: 14 Post(s)
just took the same unit out of my truck, put in a sony mex-n5000bt, now i can use my iphone bluetooth function on it. pretty sure what you want to do is not doable. my 60ui was getting the messages on the display of OFFSET and FAILER, so it made it easy to buy a new one, it worked perfect but could get the display to stop doing that.
hotrod351 is offline
Reply Car Audio, Video, and Nav
