Amp choice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-28-2014, 10:24 AM - Thread Starter
drummerguy1584's Avatar
Amp choice
Hi everyone,
I am debating between 2 amps to push my alpine spx177r components in my truck I was hoping for some insight
New model (hifonix made) MB Quart RA400.2 (found for $100)
Or
Rockford Fosgate punch p400.2 (3 options: new, last years model (factory refurb(found for $149 or the older model with the 2 chrome cover s on top ($100)
Everything will be run at 4 ohms. Any help would be appreciated...
-Sean
drummerguy1584 is offline
post #2 of 6 Old 08-28-2014, 01:33 PM
cubdenno's Avatar
Quoted: 58 Post(s)
Liked: 81
Get the one with the most power assuming both have a built in crossover. I would prolly choose the rockford with the aesthetics I liked most.
XBL-Steelhouse1
"No one wants to fight the naked guy."
cubdenno is offline
post #3 of 6 Old 08-28-2014, 01:58 PM - Thread Starter
They both have the same power rating 100 W x 2 at 4 ohms RMS I have already have an old (made ny rockford fosgate) MB Quart model RAA4200 deiving my 2 ARC audio 10d4's so I have a good experience with that but I'm torn between Rockford because I know they made that amp or between MB Quart since that's the brand that I have a good experience with.
Aesthetics don't really play a part in it since it will be under my front seat.
post #4 of 6 Old 08-28-2014, 04:34 PM
daveds50's Avatar
Quoted: 64 Post(s)
Liked: 38
keep your RF made MB... those were pretty good amps.... not sure i would use a 4 channel for subs though.
however, the Maxxsonics made MB's are pretty horrible... in fact, all Maxxsonics amps are horrible, including the ones made for other companies. the only good thing about them is their larger amps produce a lot of power. ( like the 3000 watt RMS and up Hifonics, Digital Designs, American Bass, Lanzar, etc ) but their downfall is Chinese parts that have a short life.
i work on pallet loads of these things... and i would never use one.
the RF of the generation you are looking at, is not what RF used to be. while they are not junk, they also use a lot of Chinese parts. i have a P400-2 here right now. that is a much better choice than the MB. just stay away from the newer RF, unless you are willing to pay for the Power series.
i have a load of amps coming in on tuesday. i can see if there is anything interesting. i know there are some Zapco amps in there.
daveds50 is offline
post #5 of 6 Old 08-28-2014, 04:55 PM - Thread Starter
Thanks for the input, a little dyslexia on my part, I have the old 2 channel MB RAA2400 for my subs, not the 4 channel RAA4200
post #6 of 6 Old 08-28-2014, 04:58 PM
daveds50's Avatar
Quoted: 64 Post(s)
Liked: 38
thats better. still one of the very good MB's.
daveds50 is offline
Reply Car Audio, Video, and Nav
