2 JL 13W7 or 2 KICKER Solo-X S12X?????? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-25-2006, 06:07 AM - Thread Starter
dabigpapa's Avatar
I narowed it down to two different subs I will either be gettin 2 JL 13W7 or 2 KICKER Solo-X S12X I need help deciding which couple to get PLZ advise. Thanks.
dabigpapa is offline
post #2 of 16 Old 09-25-2006, 11:08 AM
Clepto's Avatar
Hell, imo one JL 13w7 would be plenty... what kind of vehicle are we talking?
Main screen turn on. All your base are belong to us.
Clepto is offline
post #3 of 16 Old 09-25-2006, 01:28 PM - Thread Starter
dabigpapa's Avatar
They goin in a 2004 impala ss
post #4 of 16 Old 09-25-2006, 08:50 PM - Thread Starter
dabigpapa's Avatar
Well it looks like im goin with 2 13W7 so now what amps & how many do i need to handle their power & what type of batteries & how many do i need. THANKS.
post #5 of 16 Old 09-25-2006, 09:41 PM
CenterForAnts's Avatar
naturally the 1000/1s of course...have you considered other subs? for almost the same or equal output/performance for less $$$? what kinda music do ya listen to?
are you looking for more SPL or SQ, SQL?
CenterForAnts is offline
post #6 of 16 Old 09-25-2006, 09:49 PM
knukonceptz's Avatar
Vented SPL Shootout result
http://www.icixsound.com/vb/article.php?a=13
Sealed SPL Results
http://www.icixsound.com/vb/article.php?a=12
SQL results
http://www.icixsound.com/vb/article.php?a=15
So if you just want loud - the kicker beats the 12W7, but if you want it to sound good the JL woofer wins at loud and sounding good.
knukonceptz is offline
post #7 of 16 Old 09-30-2006, 08:54 AM
oldschool4life's Avatar
When using a W7, you're kinda limited to JL amplifiers (to get the most out of the amp) due to the impedance of the dual 1.5 ohm coils...
3 ohm driver on a "regular" monoblock (2 ohm stable), the amp will run "less hot"; but, you will not get all the power of the amp.
Originally Posted by oink
Mr. Cialella is, without question, the AVS honorary MOST ADMIRED PERSON OF THE YEAR.:D
oldschool4life is offline
post #8 of 16 Old 09-30-2006, 04:45 PM
BearGator56's Avatar
Quoted: 64 Post(s)
Liked: 37
I had 1 13w7 installed in my Lincoln LS. I'm not sure if you realize how big of an enclosure that two will require, let alone the power. I had an Autotek amp pushing 1200w to it. JL highly recommends using a ported box. The box for one sub took up almost all of my trunk space, and the LS has a pretty big trunk.
All I know, is I was amazed and shocked at how loud the thing was. Even the installer from Ultimate Audio was shocked. He told me that it was the loudest car he's ever done with 1 sub. Of course, this was when the 13w7 was relatively new. One 13w7 will hit 140-150 db with the right power. My previous set up was two 10w6's, and they were pretty loud, or so I thought.
In addition, if you decide to try two... Make sure you have an alternator and electrical system that can handle the strain. My LS didn't with one. Of course, I was running two other amps that were pushing 111x2 to my door speakers (Diamond Audio 6.5 seps).
In my opinion, you'll more than impress your friends with one of 'em.
BearGator56 is offline
post #9 of 16 Old 09-30-2006, 04:49 PM
Quoted: 64 Post(s)
Liked: 37
Nothing comes close to that 13w7 for sound quality or loudness, IMO.
post #10 of 16 Old 10-07-2006, 04:45 PM
16hz lover's Avatar
Quoted: 52 Post(s)
Liked: 65
But you obviously have not heard a Stereo Integrity Mag series woofer right?
The last SPL competition I went to, the Mag wooped butt over the 13W7's and it is also one of the best sounding woofers out there.
Check them out. And you don't have the mechanical sounds to deal with like the W7's have either.
Earth: The Insane Asylum of the Universe, nowhere else could things be this screwed up.
16hz lover is offline
post #11 of 16 Old 10-07-2006, 08:48 PM
iamskew's Avatar
Just a quick note: If you're going to be running some serious wattage, don't waste time with capacitors. Get a beefy alternator and good deep cycle batteries like optima yellow tops.
iamskew is offline
post #12 of 16 Old 10-07-2006, 11:59 PM
goobenet's Avatar
Heh, how big is your vehicle? A pair of these would blow the doors off most anything.
http://www.jbl.com/car/products/prod...=US&region=USA
Buck a watt. =) (plus s/h)
8110 Watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1%THD+N
They demoed it at a show once, ran a 60hz tone though it and used it as a welder! Now that's power.
goobenet is offline
post #13 of 16 Old 10-09-2006, 03:05 PM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
There's no point trying to compare JL W7's to anything else. They're in a league of their own. By the time the competition figures out a way to get around all the patents, JL will have moved on over the horizen.
Pete is offline
post #14 of 16 Old 10-10-2006, 07:02 AM
<newbs>
:rolleyes:
They are not THAT untouchable; there are products that beat W7's in some ways or another (SQ, SPL, Price, etc)...
post #15 of 16 Old 10-10-2006, 12:51 PM
mynym's Avatar
Quoted: 22 Post(s)
What makes the 13W7 so unique is that it can play at moderate SPL levels and it still sounds great. The ultimate SQL sub.
There are however a ton of subs that can play much much louder than the 13W7. Infact you'll never find a 13w7 in any DBDrag event. They just don't get that loud.
mynym is offline
post #16 of 16 Old 10-10-2006, 06:48 PM
Deathwish238's Avatar
Neither, look at other nonmainstream brands. But to answer your question, I'ld go with the JLs
Deathwish238 is offline
Closed Thread Car Audio, Video, and Nav
