Trouble with Kenwood KDC 9011 - AVS Forum | Home Theater Discussions And Reviews
Old 10-13-2006, 09:25 PM - Thread Starter
April_A's Avatar
Hi! I have a Kenwood KDC-9011 head unit in my car and today it started messing up. (actually it's my husband's car now, but anyway.....) He started the car and the face flipped around like normal, but none of the lights came on and none of the buttons are working. The remote isn't working either. You can't change the volume, radio station or do anything with the cd. The cd won't eject either. Does anyone have any idea WTH is wrong? I know it's kind of old, we got it in early 2000, but for what I paid for it I'd expect it to last a little longer. If anyone might know how to fix it I'd really appreciate your help!
April_A is offline
Old 10-18-2006, 08:04 PM
Kricket's Avatar
it sounds like one of the ribbon cables failed - i had this happen on an old kdc-x789 AND a kdc-x689 - the guy who serviced it told me that the ribbon cable failing is common on pretty much ALL kenwood units with the flipping faceplate
right now actually, my current unit works, but the display doesnt work ONLY in the display mode - basically, it works to show me the volume, cd track, and radio station preset - however, when that fades and the display is supposed to show (mines chosen to an equalizer), it just goes to black - everything works correctly, even the buttons and volume knob light up - but that darn display wont light up - im guessing thats a ribbon cable problem too
oh well - i wont get it fixed again - my kdc-x990 should be here sometime next week :D
uhhh...hd what...?
Kricket is offline
Old 10-18-2006, 09:25 PM - Thread Starter
April_A's Avatar
Thanks for the reply :) I called Kenwood the other day and they gave me the # to a local service center. I called them today and they told me it was probably a ribbon and would probably cost around $100 to fix... So my husband decided to google the part and found a forum that was pretty much dedicated to the same problem, except the model was KDC 7011. Someone had posted how to get to the ribbon, how to replace it and where to get the part. He took it apart and ordered the part, so hopefully he can get it fixed! I'd love to get an awesome system in my car, but since it's an '06 w/ Onstar and the built in phone.... Just seems like too much trouble :rolleyes:
April_A is offline
Old 10-18-2006, 10:46 PM
Kricket's Avatar
oh thats great - if your husband can do things like that (i dont trust myself since i fried a home stereo system a few years back) then its definitely worth it to try it himself - when the repair guy took mine in, it took about 25 minutes and i had it back in my hands - apparently, its a pretty easy repair (for people who know what theyre doing :) )
uhhh...hd what...?
Kricket is offline
