Bass EQ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-18-2006, 12:02 PM - Thread Starter
memnoch2's Avatar
anyone know of an outboard EQ processor that concentrates on bass frequencies only? kinda like the Velodyne SMS-1 for home theaters. there are lots of full-frequency EQ processors out there, but none have a lot of frequency bands 100Hz and below. i thought audiocontrol would have one, but all they have is the Epicenter which is a bass booster.
i am hoping for 3 bands of parametric EQs that can be set to any frequency between 20-100Hz.
memnoch2 is offline
post #2 of 7 Old 10-18-2006, 01:01 PM
Kal Rubinson's Avatar
Quoted: 681 Post(s)
Liked: 461
Why not the SMS-1? Alternatives are the R-DES or the BFD but they require some additional mardware/software for setup.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 7 Old 10-18-2006, 03:47 PM
KenWH's Avatar
Quoted: 33 Post(s)
Liked: 26
If you don't mind spending some $$$, maybe the ppi(precision power) dcx-730 would work?.?.
KenWH is offline
post #4 of 7 Old 10-19-2006, 02:23 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5339 Post(s)
Liked: 4226
My (older) Alpine deck came with 'Bass Engine Pro' so I can set my parametric EQ as low as 20hz. :D
Scott Simonian is online now
post #5 of 7 Old 11-06-2006, 01:11 AM
gooki's Avatar
or you could use 3x Phoenix Gold Bass cubes.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
post #6 of 7 Old 11-07-2006, 12:48 PM
Zues's Avatar
you dont need no bass eq. Just a good crossover like audiocontrol or the one in your deck should be fine.
Zues is offline
post #7 of 7 Old 11-09-2006, 11:42 AM - Thread Starter
memnoch2's Avatar
the bass eq is for taming peaks in the bass region, so the bass is tight and not boomy. crossovers will just transfer the frequencies below the crossover point to the subwoofer. EQs in decks do not usually go below 40-60Hz.
the Rockford Fosgate 3SIXTY processors offers some pretty neat EQ features, plus a nifty interface thru a PDA! price is reasonable too, so i may consider this.
memnoch2 is offline
Closed Thread Car Audio, Video, and Nav
